[Z06] '02 Z on Dyno
Old Jun 9, 2003 | 07:24 AM
Richy's Avatar
Richy
Default '02 Z on Dyno
Finally got a chance to see what the car was doing.Phoenix Perfomance(they
prepare cars for John Heinrecy)brought it's mobile dyno to the Corvette Club
of Delaware Valley's Annual Cavalcade of Corvettes.With only engine mods
of Blackwing intake and Corsa Indy exhaust,car produced 364 hp and 357 ft-lbs.It sounded absolutely awesome at WOT.I was sort of expecting these numbers since the car runs 12.44 sec @ 113 mph.I plan on having Phoenix
"tweak" the engine program for a little more.
Old Jun 9, 2003 | 05:42 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Default Re: '02 Z on Dyno (Richy)
Hi Richy -
Good numbers! Was this on a Mustang (two-roller) or a Dyno-Jet (one roller) dyno? Are your numbers SAE or STD hp?
Just wondering - I had mine dynoed on both types of dyno - I got my sig numbers on the Breathless Mustang dyno.
best regards -
mqqn
Old Jun 9, 2003 | 08:31 PM
case2307's Avatar
case2307
Good numbers. :cool:
Old Jun 9, 2003 | 11:48 PM
Bertrand's Avatar
Bertrand
Default Re: '02 Z on Dyno (mqqn)
Hi Richy -
best regards -
mqqn
FYI, the Breathless mustang dyno is notorious for being very optimistic. The Dynojet 248 with SAE corrected readings is the way to go for a true read in my humble opinion.
:cheers:
Old Jun 10, 2003 | 09:48 AM
Richy's Avatar
Richy
mqqn,
2 roller,SAE
Old Jun 10, 2003 | 09:52 AM
C5Longhorn's Avatar
C5Longhorn
Good #'s. Add some LT headers and you would see a nice gain.
Old Jun 10, 2003 | 10:06 PM
Sure To PleaZ's Avatar
Sure To PleaZ
:cheers:
Old Jun 10, 2003 | 10:21 PM
jackmott's Avatar
jackmott
I made 370.8 with just a K&N and the intake silencer lid removed
I add this not to be a nice guy, but because I truly believe that the cold air intakes on the market are of questionable value.
[Modified by jackmott, 3:22 AM 6/11/2003]
Old Jun 11, 2003 | 01:08 AM
Weedo's Avatar
Weedo
12.44 with 364HP? Wow, i can't wait to get my car to the track!
:thumbs:
Old Jun 11, 2003 | 02:14 AM
jackmott's Avatar
jackmott
Default Re: '02 Z on Dyno (Weedo)
people have nabbed 11.9 with that much power.
takes a good track. good weather and a good driver though.
Old Jun 11, 2003 | 02:52 AM
Richy's Avatar
Richy
Default Re: '02 Z on Dyno (jackmott)
Weedo & Jackmott,
Of course you are right.The car is certainly capable of much more with a better driver.The 12.44 time was with a 60' time of 1.944sec.I've been experimenting with tire pressure which seems to have a considerable effect.One of the problems has been lack of track time since 4 out of 6 events
were cancelled due to rain.Another big item affecting the ET is that I don't powershift.This car is my only daily driver and I can't afford to break it.Right
now I just plan(if the weather ever improves) to work on my launch.
Any suggestions are more than welcome.
Old Jun 11, 2003 | 08:39 PM
Weedo's Avatar
Weedo
Richy, don't get me wrong, i think that's a GREAT time for the power you're putting down. I'm hoping for low 12's with the Supercar tires putting down 392HP. Then again, our tracks here suck, the weather is hot, and I have NO track time with this car. So I think you're doing great!
Old Jun 11, 2003 | 09:38 PM
Power Shifter's Avatar
Power Shifter
Richy, nice numbers. 1.94 is a good 60' on some days depending on track conditions it's very good. The best I can offer as far as advice for better 60' is time trials, when your weather clears. Trying the differant combinations of clutch release speed combined with differant fuel increese speed can only be learned from actual runs, the number of combinations to try goes up expotentialy when you add in tire pressure and launch rpm. No way around practice and trial and error with limited traction vettes. Ric
Old Jun 12, 2003 | 01:28 AM
Richy's Avatar
Richy
Default Re: '02 Z on Dyno (Power Shifter)
Thanks for the advice,Ric.Hope you can make it down to Etown for a few of the Challenge events.
To '02 Z on Dyno
