[Z06] Track Tires & Wheels
Old Jun 9, 2003 | 03:04 PM
ZO6 2GO's Avatar
ZO6 2GO
Default Track Tires & Wheels
Please post recommendations for Tires, Size and aftermarket wheels for track use only. I will be installing the full T1 Suspension. Also if you have done brake upgrades cost and your thoughts on improved braking at the track.
Old Jun 9, 2003 | 04:55 PM
Z11409's Avatar
Z11409
Default Re: Track Tires & Wheels (ZO6 2GO)
I have good luck with 18"s all around using all stock wheels.Tires are GY 26 x 11.5 - 18 Yellow letter slicks,480 compound. No problems with Hawk plus pads,good fluid and power slot potors with additional air ducks and deflectors.Insulate front tie rod ends or replace with quality units.Lots of negative camber is needed to make tires work.Wheel bearings do suffer shortened life span.
