Cleartastic is on!
Old Jun 9, 2003 | 09:11 PM
LS7's Avatar
LS7
Default Cleartastic is on!
Just installed the full 14 piece Cleartastic kit. Took me about 2 hours b/c it was my first time and b/c I'm a perfectionist. Followed the instruction's exactly and had no problems. Everthing fit nice. I used the California squeegee and my credit card to smooth out the pieces. You can't even tell that the pieces are on the car unless you'r looking for them and your about 2 feet away. I just got the 3 piece mirror set also. I'll probably put that on tommorrow. Right now the car is under the cover and I'll be taking it to work tommorrow so I'll let you know how it hold's up. BTW, I get to go about 130 mph on this one stretch of road so I'll check to see if everything is there when I get home. I think there tested up to 160mph so I should have no problem. :auto: :thumbs:
Old Jun 9, 2003 | 09:36 PM
wireless's Avatar
wireless
Photochop Terrorist
Default Re: Cleartastic is on! (LS7)
Do they stay on when you wash? What about in the rain? (Seriously, the car doesn't melt. :rofl: )
Old Jun 9, 2003 | 09:50 PM
meyerld's Avatar
meyerld
Do they have a piece for the leading edge of the convertible top lid - every time I raise or lower my convertible top, it rubs the center leading edge of the lid when it is raised.
Old Jun 9, 2003 | 10:14 PM
Ken's Electron Blue's Avatar
Ken's Electron Blue
Default Re: Cleartastic is on! (meyerld)
LS7
Any installing tricks you can pass on to us, I just got a set and have not had time to do the installation yet?
Old Jun 10, 2003 | 01:09 AM
C5FAST's Avatar
C5FAST
Took me about two hours to apply mine too. I found out that it worked well to add a piece to one corner and let it dry awhile before placing the overlapping piece (work on another corner instead). I am very pleased with them. They stay on great when you wash the car and they stay on in the rain. Someone asked about a piece for the convertible, my neighbor has a C4 vert and he has a piece that prevents the top from rubbing on the paint so you should look into it. Glad to hear yours went on so well. The mirroror pieces are a little bit tougher however. :seeya
Old Jun 10, 2003 | 03:08 AM
Shylor's Avatar
Shylor
PICS!
Old Jun 10, 2003 | 08:02 AM
LS7's Avatar
LS7
If you have any question's about convert pieces or general questions about the product, call Ed at Cleartastic 1 800 778 9898. That's what I did and he was very helpful. Also, check out their website. Their company is on the homepage of corvette forum to the left. Just scroll down.
Regarding installation tips, follow the instruction's exactly . I got a 8 oz. spray bottle, filled it with water and mixed one drop of Dawn liquid soap in it. Don't shake it up b/c you don't want bubble's. Just swirl it in the bottle. Spray on your finger's to make sure it doesn,t feel soapy. Clean the areas on the car well and wax them with a good carnauba wax before applying. Spray the area's with the water, wipe it off to get off any dust, and spray again. Peel off the Cleartastic and spray it. Then apply. It position's into place easily. The big California Squeegee I got at Auto Zone worked great to get it started and then I used the credit card to really smooth it out and get the water out. I send PICS as soon as I can figure out how to download them to the forum. :cool: :thumbs:
[Modified by LS7, 1:04 PM 6/10/2003]
Old Jun 10, 2003 | 08:32 AM
joeking's Avatar
joeking
Cruise-In II Veteran
Cruise-In III Veteran
Sounds great...might have to try it instead of running the bra on trips. :thumbs:
Old Jun 10, 2003 | 09:43 AM
SolarAngel's Avatar
SolarAngel
I was just thinking about investing in that. Did you get the 14 piece set? What does it cover? Where'd you get them from?
Old Jun 10, 2003 | 11:22 AM
TNT C5's Avatar
TNT C5
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Default Re: Cleartastic is on! (SolarAngel)
You'll have that install time down to twenty minutes in no time. I soak mine in hot water before I install and use a mixture of 1/2 Z6 and 1/2 distilled water to spray the surface beforehand and was amazed at how much simpler it made it. Also, when they say the surface must be clean....it must be clean. I was frustrated with the time it took to put them on initially but when I read the above tip, it really made it a no brainer. Also, Ed at Cleartastic is one stand up vendor. He is committed to our satisfaction with the product. Good luck! :thumbs:
Old Jun 10, 2003 | 03:50 PM
mcramer's Avatar
mcramer
Default Re: Cleartastic is on! (joeking)
I'm thinking that the standard "home installation" cleartastic doesn't cover the front of the car. :confused:
Old Jun 10, 2003 | 05:16 PM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
Default Re: Cleartastic is on! (mcramer)
Ed told me they don't yet have a cleartastic "bra". It's in the works.
Old Jun 10, 2003 | 09:09 PM
LS7's Avatar
LS7
The 14 piece set covers behind the front wheel wells, the lower sill in front of the rear wheel wells,( thats where most of my scratches were ) behind the rear wheel wells, and the inside of the front and rear wheel wells behind the tires. I'm glad I returned my Altec painted splashguards in place of Cleartastic. The Altec splashguards looked cheap and the paint didn't match well. My car is Pewter. Also, I didn't want to drill 12 holes in my Vette to install them. Go with the Cleartastic. :thumbs: BTW, I didn't get to reach 130mph on the way home today b/c of traffic but I did get up to 110 mph and when I got home all the pieces were still there. I also ordered the 2 piece set which cover's in front of the rear wheel wells and I installed them on the front of the car on both sides of the license plate and they are still there. This will at least help with the scratches in the front bumper untill they make a full front bumper piece. :hurray: :seeya
[Modified by LS7, 2:14 AM 6/11/2003]
Old Jun 10, 2003 | 09:29 PM
Ken's Electron Blue
LS7
Thanks for the tips on installation, I/m looking forward to getting them on. If they work out as good as I/m hoping they will, I will look forward to the clear bra product, that would be great.
Old Jun 10, 2003 | 09:30 PM
WellAdjusted's Avatar
WellAdjusted
From: His name is Tandy Dillen. Altruism is the last Frontier.
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
St. Jude '03-'04-'05-'06-'07
LS7,
Thanx for the post. I was ignorant about this product. I surfed the site. There's nothing in there about how to store them once removed. Is there a protective backing that can be saved and re-used? My fear is that once off they will collect dust, etc and not re-seal upon reapplication. Any thoughts on this?
Thanx.
Old Jun 11, 2003 | 07:44 AM
LS7's Avatar
LS7
Default Re: Cleartastic is on! (WellAdjusted)
Well Adjusted,
To store them, all you have to do is stick them back onto the white paper they are individually shipped on. Save the cardboard piece that they are mailed in B/C it will keep them nice and flat when storing. :hurray: :seeya
To Cleartastic is on!
