[Z06] Side molding removal.
Old Jun 11, 2003 | 01:28 PM
HFRAZ's Avatar
HFRAZ
Default Side moulding removal.
Has anyone removed the side moulding on their Z06? I am considering removing the moulding on my Z06. What is the best method? Are there any particular solvents that work best to remove adhesive without damaging clearcoat? Should I use a heat gun to soften adhesive? Do you guys think our vettes look better without the molding? Thanks for your input/information. Hank
[Modified by HFRAZ, 2:26 PM 6/11/2003]
Old Jun 11, 2003 | 01:55 PM
ppk1911's Avatar
ppk1911
Default Re: Side molding removal. (HFRAZ)
just took them off this past weekend-- very easy-- see my post: http://forums.corvetteforum.com/zerothread?id=580340
Old Jun 11, 2003 | 01:57 PM
jerryv's Avatar
jerryv
Do a search on BSM removal ... there have been lots of posts. Basically, you use 15# - 20# monofilament fishing line to 'saw' thru the double-sided tape which holds the bsms, then clean up the remaining glue 'stripes' with GooGone, WD40, etc or by rolling it off with your thumb.
Old Jun 12, 2003 | 01:41 PM
av8or3's Avatar
av8or3
Default Re: Side molding removal. (Jerry Velders)
:iagree: That's how I got mine off. I like the clean look better.
To Side molding removal.
