[Z06] Polished ZO6 wheels.
There has been quite a bit of disussion here in the past regarding this subject - try a search to see what you come up with.
There is a place in Vancouver called Panther Precision Machine - here is a url - http://www.pantherwheels.com/
Of course there are several places that ofer an OEM exchange program for OEM wheels to get them chromed.
And did you know that the Commemorative Edition (rpo Z16) Z06 will have polished Z06 style rims?
best regards -
mqqn
[Modified by mqqn, 9:10 PM 6/15/2003]
No problem :thumbs: - The answer to why may lie in the money - You can buy aftermarket chromies for $1100 and keep your stockers for a rainy day...
I have heard that the '01 stock wheels are better suited to polishing than are the '02+ wheels - but I have no first hand experience to report.
I have seen the polished - and while these are good looking - they do not "pop" like chromies - purely my opinion.
best regards -
mqqn
I often wonder the same thing - since I track my car, I don't want to risk the build quality of some aftermarket wheel, specifically an OEM knock-off. Just don't want that extra conern with a activity that's already a little dangerous and "equipment intensive".
A couple of things on the polishing (and not maching like some companies provide). There was some concern voiced from a polishing shop that the cast wheel (i.e., 02-03) had tiny fissures, that would become more evident with polishing, and cause some discoloration. I have no idea about this, just passing it on - the same shop said the forged wheels (from '01) were better suited.
Here's the thing - I had wheels on my previous ride that were cast. I actually had the wheels disassembled (3-piece), polished, the back 1/2 painted dark to hide dirt/dust (also put back together with ARP 180K psi fasteners - they looked great and I never had any problems - no corrosion, pits, etc. They only hassle was the exposed aluminum hazed over quicker than a chrome or painted finish, so I spent alot of time with Blue Coral chrome/aluminum polish :D (it actually helped to keep the shine longer).
Here's a pic of a hand/machine polished, cast wheel - I like this finish actually better than chrome:
Click for _much_ larger image!
Seeya -
DT
[Modified by DT, 2:10 AM 6/17/2003]
I emailed you some pics of my polished wheels. The one inside was taken a few weeks ago.
There was some concern about the cast wheels being too porous to be polished. But as you can see on mine it was not a problem.
The wheels were polished 18 months ago and were not clearcoated. I waxed them when I got them back and have not touched them since, except for normal washing. I know it is hard to believe they have not tarnished after 18 months but they have not. It is hard for me to believe, too.
Dave
Dave
And, since the Z16 will likely use the speedline wheels, GM must think they are ok to polish as well - you were just ahead of your time! :thumbs:
best regards -
mqqn
Hi corvette dave -
best regards -
mqqn
First time I was ahead of anything!
You are right about the "pop" of the chromies. I have had them and wanted a little less"pop" this time around.
I also like the machined look I have seen on this forum.
Dave
http://www.caswellplating.com/
They have loads of info, plus all the supplies! I'm seriously thinking about picking up a set if used Z06 wheels, then I can really take my time and try it myself! Sounds pretty straight forward, just very time/labor intensive. Then, assuming I get them the way I want them, I can sell my existing OEM wheels and have a polished set for the difference (if any) on my wheels, plus the supplies.
If I decide to give this a try, I'll post my progress here!
Seeya -
DT
