Get an 01 just turned 12000 with no oil burn. :steering: :steering: :steering: :steering: :steering: :steering: :steering: :steering: :steering: :steering: :steering:
[QUOTE]congRATs ......... but if ya drive it at low load hi rpms, it will probably burn a little :yesnod:
that low load hi RPM causes a little ring flutter which allows the oil to blow by
Tony is right, if you down shift into corners you get ring flutter and burn oil. Not enough to warent new rings for me, but each to there own. Don't let anyone tell you the 01 isen't a steller car, it is. Mine ran an 11.9x with the stock lid and tires! The 02's are just a scosh faster, and I liked the electron blue. Ric
