[Z06] Skip Shift Plug Seal Kit '03 ZO6
Does anyone else have the Skip Shift installed?
Regards,
scubaboy
'03 ZO6 Johnny Cash BLACK
:conehead
I purchased a set of Rhino Ramps, and they make getting the car off the ground much faster, easier and safer. You can get these at WallyWorld or Autozone for less than $30. You only have to raise the rear of the car to install the CAGS eliminator kit.
2) Wiggle yourself under the rear of the car.
3) Look for blue and white electrical connector on driver's side of tranny (near the top-rear of tranny).
4) Unplug the wire from that connector (lift locking tab and pull with fingers -- it may be tight).
4a) (optional) Utter expletives while removing dirt that was loosened in step 4 and has now fallen into your upward-gazing eyes. Make mental note to wear eye protection next time.
5) Plug one part of CAGS bypass into now-empty socket on tranny.
6) Plug other part of CAGS bypass into now-loose wire unplugged from tranny in step 4.
7) Zip tie wire from step 6, so that it isn't hanging loose and getting into trouble.
8) Get out from under car, because you're done!
Total time under car: 1 minute (3 minutes counting step 4a)
Cheers,
Kent
[Modified by Kent1999, 12:04 PM 7/13/2003]
Thanks for the link to your how to's. :D
While I know your response was directed to the CAGs I found the sections on speaker replacement of interest to me.
Thanks for the pics.
John :cheers:
