[Z06] shift points
Old Jul 7, 2003 | 10:32 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
Default shift points
Anybody know what RPM is the best to bang shifts in a race w/ my 03 ZO6? I'd keep my right foot on the floor of course,but not sure where the best shift points are for 1-2,2-3,3-4. Thanks!! :auto:
Old Jul 8, 2003 | 12:28 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Default Re: shift points (Dr.Ron)
These ls6s pull like trains all the way untill 6500, so shift at 6300ish and you'll be banging out shifts at redline! I personally wouldn't powershift my ride (speedshift as fast as I can) due to the extra strain on the drivetrain, but it's your car and that is the fastest way from point A to B. :cheers:
Old Jul 8, 2003 | 02:22 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Someone posted a detailed analysis of this problem in C5 tech a few weeks ago. Basically, you want to keep the engine as close as possible to it's peak torque RPM at all times.
This means running up PAST the peak torque RPM by an amount that is exactly as high above the peak torque number as the "new" (after shift) RPM is below it.
The guy also concluded that shifting at redline was usually the right answer!
Perhaps someone has already done the math for the stock Z06 dyno numbers and transmissions ratios?
Old Jul 8, 2003 | 06:53 PM
FLYNLO's Avatar
FLYNLO
Default Re: shift points (SDVette)
The ZO6 dyno climbs all the way to redline......so you want to shift as close to redline as possible.
Old Jul 8, 2003 | 07:21 PM
SDVette's Avatar
SDVette
Default Re: shift points (FLYNLO)
Actually, in the couple dynos I have looked at, the torque peeks at around 5K RPM, while the HP peaks at redline.
Here is one from on 03 Z06: http://forums.corvetteforum.com/zerothread?id=593547
Old Jul 8, 2003 | 07:57 PM
FLYNLO's Avatar
FLYNLO
I guess when I said "dyno", I ws referring to horsepower. To put it very simply, torque gets you going and horsepower keeps it going. I don't think you are suggesting we shift at 5000RPMs now are you??? :) :)
Old Jul 8, 2003 | 08:05 PM
SDVette's Avatar
SDVette
No, not 5K.. But maybe something less that 6500????
I wish I could find the link, but I cannot locate it now.
I think it all comes down to how many RPM you "loose" on the shift. Your MN12 has closer ratios than my MN6, so you will "loose" less RPMs on a shift.
Maybe there is an optimum shift point a little below the red line on the Z06???
Who's got the ratios and done the math?
Old Jul 9, 2003 | 12:30 AM
Dr.Ron's Avatar
Dr.Ron
I would think red line shifts (especially a power shift) would bounce me off the rev limiter,no??? As you know, during power shifting, your right foot stays planted on the floor. As you bang the shift and hit the clutch the engine lurches ahead in RPM's. I used to power shift my Mustang @ 5500 RPMs @ Englishtown. Seemed to work. ;)
Old Jul 10, 2003 | 07:10 PM
Tom Steele's Avatar
Tom Steele
Yeah, me too (not Englishtown, but a 93 Mustang Cobra.) But the Cobra's redline was somewhere in the neighborhood of 5,500 and the rev limiter didn't kick in until 6,100 or so...
That gave plenty of room for power shifting. If you are shifting a Z06 at 6,500 rpms, it seems to me that if you leave the car WOT, you will bounce of the limiter... Maybe that won't matter, because as soon as you engage the next gear it should be fine, but I'd rather speedshift the car and not risk hitting the next gear with the rev limiter engaged.
I'd be willing to try powershifting if it works though.
Old Jul 11, 2003 | 12:01 AM
Power Shifter's Avatar
Power Shifter
Default Re: shift points (Tom Steele)
The theory is you look at the efective drive shaft torque at your shift point, and then also look at the drive shaft torque after your shift to try to maximize acceleration. This is how you get the numbers: drive shaft torque=flywheel torque X transmision ratio.: You can figuer rpm after your shift by divideing the ratio of the gear your shifting into by the ratio of the gear your shifting from X rpm before you shift. You will find that the person-s that say there shifting at red line either have raised there limiter, don't look at there tach and are actualy guessing at the shift point or there not power shifting. If your power shifting, 6300 is the rpm I useualy shift. But there are many variables and what most starting out don't fully understand, is when you change one variable it has an efect on all the other variables, changeing them also. The corect answer to best shift point is also a variable for that reason. Get out to the track and have fun finding the best shift points for your driveing style. Ric
To shift points
