[Z06] Z06 High Idle code set check engine light still on
Old Jul 16, 2003 | 10:11 AM
badgerbob27's Avatar
badgerbob27
3rd Gear
Default Z06 High Idle code set check engine light still on
We have a 2003 Z06 with a problem. Only mod is the CAGS eliminator. On the Z's virgin voyage to Nashville/Bowling Green got a check engine light. Dealer in that area scanned it and said it was a high speed idle but nothing to worry about. They also said couldn't clear check engine light with CAGS disconnected. Is that true? sounds fishy to me. Can anyone tell me now to clear the code and get rid of the check engine light without taking it in to the dealer? Yes I could reconnect the CAGS but how would I then clear the code to turn out the check engine light? Your help would be appreciated. Thanks
Old Jul 16, 2003 | 11:03 AM
SmokieTheZ's Avatar
SmokieTheZ
Default Re: Z06 High Idle code set check engine light still on (badgerbob27)
:bs They are full of it (I think). Check this page out for going through the error codes yourself.
https://www.corvetteforum.com/techti...D=26&TopicID=1
I've had a few error codes but was always able to clear them. !CAGS from day one...
:cheers:
Old Jul 19, 2003 | 10:34 AM
CP's Avatar
CP
Check this thread out. This guy seems to have the same problem as you: http://forums.corvetteforum.com/zerothread?id=605783
To Z06 High Idle code set check engine light still on
