[Z06] Tranny Fluid?
Old Jul 16, 2003 | 07:17 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Default Tranny Fluid?
What type of fluid is OE in the car?
Synthetic or not?
TIA for your help.
Old Jul 16, 2003 | 07:28 PM
Maineiac's Avatar
Maineiac
From: Making my carbon footprint as BIG as possible
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude '03-'04-'05-'06
Default Re: Tranny Fluid? (Z06ufgrad2002)
I don't think it's synthetic. I just bought some Redline for mine, going to change it Sunday. :thumbs:
Old Jul 16, 2003 | 08:57 PM
silverz06vette's Avatar
silverz06vette
Default Re: Tranny Fluid? (Maineiac)
The oem fluid is not synthetic. It is ATF and that is what needs to go back in.
Old Jul 16, 2003 | 09:01 PM
Z06ufgrad2002
Default Re: Tranny Fluid? (silverz06vette)
The tech at the dealership says he can put GM Synchromesh in it instead of the Dexron III that came in it. So this would be replacing the ATF with a synthetic. Is the dealership wrong in this statement?????
Old Jul 16, 2003 | 09:12 PM
gmblack3's Avatar
gmblack3
The oem is ATF non synthetic, You can run synthetic ATF Dex III in the tranny: mobil 1, amsoil or redline.
Here is the reply I got back from tremec about the use of synchromesh tranny fluid in the Z06:
Our recommended oil for the Z06 transmission is Dexron III. We feel that if you wanted to use the GM Synchromesh, we do not see an issue but have not done any testing for this. I do not know the GM Synchromesh would impact the carbon rings in the syncjronizers.
I would just make sure its noted on the receipt, that way if it screws up the tranny then they can fix it.
Old Jul 16, 2003 | 09:17 PM
Z06ufgrad2002
Default Re: Tranny Fluid? (gmblack3)
So what exactly is the GM Synchromesh fluid? A synthetic gear oil??
Old Jul 17, 2003 | 12:00 AM
gasboy's Avatar
gasboy
i tok the dexron III out of mine and replaced it with redline d4 atf.instant smoother shifting.
To Tranny Fluid?
