[Z06] Memory seat question
Old Jul 18, 2003 | 08:06 AM
dubya's Avatar
dubya
St. Jude Contributor
Default Memory seat question
I have noticed that my '02 Z06 drivers seat does not automatically adjust when I insert the key. I have to push the memory button on my door. Is this normal?
Also, when I remove the key the seat does not go "all" the way back like my coupe did. Is this normal?
Given this information you probably quessed it. I'm 5'5" and I like to be right on top of the steering wheel. :steering:
Thanks for the help
Old Jul 18, 2003 | 09:03 AM
sanz442's Avatar
sanz442
8th Gear
Default Re: Memory seat question (dubya)
If you hit the unlock button on the key fob before you get in the car it will adjust the seat when you insert the key (providing you are using the proper key either key 1 or 2). On the DIC go to your options and see if the selection is active for the seat moving back on exit.
Old Jul 18, 2003 | 07:04 PM
dubya's Avatar
dubya
Default Re: Memory seat question (sanz442)
Thanks Sanzz,
The first suggestion worked.
My seat does retract when I remove the key, but not all the way back. Any other suggestions?
To Memory seat question
