[Z06] GM fix a flat
Old Aug 15, 2003 | 10:41 PM
DAKING's Avatar
DAKING
Default GM fix a flat
Do you have to replace tire sealant with the GM (DUNLOP) or can I use something else. It's expensive!
Old Aug 18, 2003 | 10:10 AM
EvanZR1's Avatar
EvanZR1
C4 of Year Winner (performance mods) 2019
Default Re: GM fix a flat (DAKING)
You can use any tire sealant. There is nothing special about the GM stuff, as a matter of fact I'd guess that it's just rebranded Slime or something similar. When I bought my 01, the sealant was empty so I threw a couple of cans of Fix-a-Flat in the trunk instead. Haven't had to use them on the Z, but I've used them several times in the past on other high performance tires (up to 315/35R17) with no problems.
Old Aug 30, 2003 | 09:11 AM
1vette98's Avatar
1vette98
I missed this topic earlier, so excuse me for bringing it back up. Does using products like this have any adverse effect on the tire pressure sensors, and how many cans does it take to inflate a tire enough to get you to help? Thanks
Old Aug 30, 2003 | 09:42 AM
av8or3's Avatar
av8or3
Default Re: GM fix a flat (1vette98)
Do not use fix-a-flat on a tire/wheel with pressure sensors installed.It will
surely mess them up.
To GM fix a flat
