[Z06] Another trany question
v/r
THE YAV :chevy
Thats exactly what is happining when the car is NOT moving. It happened to me again this morning feels like the gears are spinning when I try to go into Reverse/or will grind like its not engauaging only happens in Reverse. I will try to double clutch. The tech I am talking to is very knowlegable with vettes however just wanted a second opion.
v/r
THEYAV :chevy
Now, to earn a Master's in gearbox use, you have to learn how to double clutch into a non-synchronized reverse gear while coasting backwards. ;)
Duke
Tried your technique worked great. Maybe this should be included in the Z video. I have had lots of stick cars in vettes however the MN12 is sometimes tempermental!!!
v/r
THEYAV
:chevy
I spent about $3,000 on my 6-speed in my '95 and it wasn't a great deal better when I got it back. It really needed the master/slave cylinders replaced in the hydraulic clutch system...
v/r
THEYAV
:chevy
Transmissions have improved over the years and we've been spoiled by better hardware that will take an amazing amount of abuse and ham-fisted operation. The fact that my dad spent the pre-war years as a field engineer with the Pontiac sales and service organization was a plus. He knew the insides of a car down to the lowest level of detail, and he taught me how to get the most out a car without beating it to death.
A couple of other tips. Say your're approach a stop sign. You slow down and work sequentially down to second gear. As you slow to a stop, declutch, let out the clutch in neutral then declutch and shift to first. It will go in much easier. This is essentially a double clutch, but there's no need to blip the throttle.
While in neutral waiting for a signal to turn green, when you see the other side go yellow, declutch, but wait two to three seconds before shifting to first. This will allow the clutchgear/countershaft to spin down, saving the syncronizer the job of stopping it before first gear can be locked to the mainshaft.
Duke
[Modified by SWCDuke, 11:55 AM 8/21/2003]
