[Z06] Is brake squeek a problem for corvettes
Old Aug 24, 2003 | 01:19 AM
WisconsinVETTE's Avatar
WisconsinVETTE
Senior Member
Cruise-In V Veteran
Default Is brake squeek a problem for corvettes
I thought I remembered some people saying that there brakes squeeked. Is this something that a lot of vettes have? I am about ready to get new rotors or pads because it drives me nuts. :banghead:
People should notice the car because it looks great or sounds great not because it squeeks every time I roll up to a red light.
Old Aug 24, 2003 | 03:13 AM
larrysb's Avatar
larrysb
Default Re: Is brake squeek a problem for corvettes (WisconsinVETTE)
Mine doesn't squeak in the slightest, either with the OEM pads or the Delco ceramics I put on 2 weeks ago.
The GM pads come with a complete set of clips, shims and stuff. It seems to make a difference.
They are really easy to change though.
If you rotors aren't warped or deeply scored, then try a new set of pads, making sure all the shims and clips are properly installed.
Old Aug 24, 2003 | 09:16 AM
jackmott's Avatar
jackmott
yes, they will squeak sometimes.
so do porsche breaks.
did you want a showcar or a performance car?
regular vette brakes pads will be more your style if you want quiteness rather than track readyness.
Old Aug 24, 2003 | 09:31 AM
Greg H's Avatar
Greg H
Now that mine have about 6,000 miles of wear on them, they squeal like crazy. That's the tradeoff for the compound used on the Z pads.
If you're willing to sacrifice maximum stopping power, try the stock C-5 pads. Others on the forum have had good luck with aftermarket pads.
Old Aug 24, 2003 | 11:36 AM
WisconsinVETTE
Senior Member
Cruise-In V Veteran
Default Re: Is brake squeek a problem for corvettes (jackmott)
Show car or performance car?:rolleyes:
I dont care if I am driving a pinto to the junk yard, squeeling brakes are gonna drive me nuts.
[Modified by WisconsinVETTE, 4:36 PM 8/24/2003]
Old Aug 24, 2003 | 06:16 PM
Tracy's Avatar
Tracy
I've had no squealing in 11K miles of driving my 03. However, I often make bigtime/high-speed/full ABS mode stops, and this "cleansing" may be why I have no problems. Maybe. I don't know for sure, just a suggestion.
Just last light I did a 140-to-30 "shoulder belt stretcher", and then cruised for few miles to make sure things cooled down evenly. Man, these brakes work good!!
Old Aug 25, 2003 | 08:35 AM
jackmott's Avatar
jackmott
My point is that the z06 was designed to please people who want ultimate track and autocross performance, not to please people who like quite soft cars. It just so happens that in this universe, nobody knows how to make a brake pad that performs really well AND doesn't make any noise.
Anyway your problem is easily solved with a set of non-z06 corvette pads.
Old Aug 25, 2003 | 09:02 AM
Corvette SSX's Avatar
Corvette SSX
St. Jude Donor '08
My 4 week old 03's breaks do squeek. Nothing too bad at the moment, but still a little annoying. I'll live with it until it gets too bad or the pads need to be replaced. Probably won't replace with the stock pads though.
Old Aug 25, 2003 | 09:54 AM
jerryv's Avatar
jerryv
The brakes will squeak if habitually used very lightly. Make a few more aggressive stops every now and then and it won't squeak.
Old Aug 25, 2003 | 01:13 PM
Go Low's Avatar
Go Low
I've got about 3500 miles on my car. These brakes squeal like like a bunch of pigs. I was told this is normal for high performance brakes. It is a little embarrasing squeeking up to a light. Hammer down when it goes green(no more embarrasement!) :thumbs:
Old Aug 25, 2003 | 01:54 PM
Tracy's Avatar
Tracy
Default Re: Is brake squeek a problem for corvettes (Go Low)
C'mon, guys!! If your brakes are squealing, do a few high speed stops like several of us have suggested, see if it solves the problem, and report back to this thread.
Make sure you do a good cool-down drive after hammering the brakes.
Old Aug 25, 2003 | 03:28 PM
Cool Ryd's Avatar
Cool Ryd
Default Re: Is brake squeek a problem for corvettes (Tracy)
:iagree: And for the one driving the pinto, he must be in a junk yard!! :yesnod: :yesnod: :yesnod:
Old Aug 25, 2003 | 06:28 PM
kraff's Avatar
kraff
6K, no squeaks. 3 road course weekends however, as stated, I think this keeps them quiet. I had a set of Hawk streets on my coupe, squeaked for awhile and one day at the track quieted them down. A couple of hard stops followed by some cooling should do the trick. :cheers:
Old Aug 25, 2003 | 08:37 PM
Greg H's Avatar
Greg H
I'm going out now to give this a try. I'll report back later tonight. :steering:
Old Aug 25, 2003 | 09:59 PM
Greg H's Avatar
Greg H
Default Re: Is brake squeek a problem for corvettes (Greg H)
Did four "panic" stops from 90+ with about 15 miles of 65-70mph driving after each stop to cool things down.
Then drove around the neighborhood, stopping and starting from various speeds. Absolutely no squeaks right now. Will check in the morning to see if squeaks come back when the brakes cool.
If they do, I guess I just need to make a few high speed runs and stops each time I drive the Z to "clean off the pads"... :D
Old Aug 25, 2003 | 10:49 PM
Tracy's Avatar
Tracy
Way to go, Greg H. I hope they stay quiet for a while.
It does seem that those of us who go into "maximum deceleration mode" on a regular basis don't have the squeals [except squeals of fear from our passengers who have NO IDEA what it feels like to go from 150 to 30 in a calm, controlled, violent manner!].
Old Aug 25, 2003 | 11:36 PM
WisconsinVETTE
Senior Member
Cruise-In V Veteran
Guess I will have to try this out next weekend when I get the car out again.
Hope it works. :D
To Is brake squeek a problem for corvettes
Old Aug 26, 2003 | 10:15 AM
jerryv's Avatar
jerryv
They don't even have to be full panic stops, just good aggressive braking every now and then is enough to keep them quiet under normal use.
Old Aug 26, 2003 | 10:45 AM
Tracy's Avatar
Tracy
Default Re: Is brake squeek a problem for corvettes (Jerry Velders)
Jerry is probably right, but one man's aggressive braking is another man's panic stop. However, because we have this wonderful ABS system, nobody should be afraid to simply hammer the brakes from highway speeds down to near zero every now and then.
Make some black dust and kill the squeal!!!
Old Aug 26, 2003 | 12:50 PM
Wah's Avatar
Wah
You have either glazed the rotors or accumulated enough dust to make it squeak. The latter is unlikely since most of us like to keep our cars clean ;) So, most likely you have glazed the rotors. Nothing like heavy braking that will wipe out the glazing (from donuts too :D ). A single run at your local autox will take care of the problem.
Remember, if you don't have scores on your rotors, you don't drive the car fast enough ;)
