[Z06] Delrin Hardbar
Old Aug 27, 2003 | 06:44 AM
Shylor's Avatar
Shylor
Default Delrin Hardbar
Where is the best place to purchase the Delrin Hardbar for less than the $60 everyone seems to want? I really want this shift **** but can't seem to justify spending $60 for it.
Old Aug 28, 2003 | 07:09 AM
Shylor's Avatar
Shylor
Default Re: Delrin Hardbar (Shylor)
Guess not....... :(
Old Aug 28, 2003 | 08:05 AM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Post that you are looking for a used one in the parts for sale section. I have bought two from there and both were under $40 shipped.
Old Sep 2, 2003 | 09:03 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
LGM has them in stock and they are nice
Old Sep 3, 2003 | 06:59 PM
kwillmorth's Avatar
kwillmorth
I bought mine at:
http://www.thelapd.com/Merchant2/mer...ory_Code=sknbx
I love it and think it's worth the $60. Over time the material gets poished from use and feels very nice. Doesn't get hot, and is the right size.
However, I did bore out the bottom thread section to shrten the overall shifter height. Between that and the Ripper, you get a very short finished installation, and very short shifter action.
http://www.lumenique.com/Cars/zo6/shifter.htm
Don't sweat a few dollars. Sixty bucks won't even buy a decent bottle of Scotch these days!
:cheers:
[Modified by kwillmorth, 12:00 AM 9/4/2003]
Old Sep 3, 2003 | 10:36 PM
Silver Ghost's Avatar
Silver Ghost
Default Re: Delrin Hardbar (kwillmorth)
If you aren't sold on the Hardbar, definitely check out MGW's stuff. Great price, around $45 and it's the best quality I have ever seen.
http://www.mgwltd.com/
Old Sep 3, 2003 | 11:32 PM
Z06_Bob's Avatar
Z06_Bob
Default Re: Delrin Hardbar (Silver Ghost)
Kevin,
What did you use to bore out your Hardbar with? Was it a tough job? I too was interested in the Hardbar, but I've heard that they sit up higher than the stock shift ****, so that kind of turned me off to it. If I could bore it out, so it sits lower, that would be ideal.
TIA,
Bob
Old Sep 4, 2003 | 11:18 AM
kwillmorth's Avatar
kwillmorth
Default Re: Delrin Hardbar (Z06_Bob)
I just happened to have a 11/16" drill bit, so chucked it in the drill press and it was done. Took all of a minute.
I know of several others who have used a Dremel tool with a sinding drum bit, simply sanded out the threads. Delrin is very easy to work with, so this wouldn't take long to do either. The entire interior of the handle is threaded, so being precise is not a major issue.
:cheers:
To Delrin Hardbar
