[Z06] Key, Remote Lock, Seat Memory Issues
Old Sep 3, 2003 | 02:05 PM
barondw's Avatar
barondw
Default Key, Remote Lock, Seat Memory Issues
My alarm went off Monday with no one around. I shut it off and unlocked the car remotely and found the radio on full blast and the warning chime ringing.
I started the car and manually shut-off the radio but could not lock the car through the remote. I locked the car manually and everything seemed fine. Alas on Tuesday the car was deader than the proverbial doornail.
Car has been flatbedded to the dealer and yes the battery is dead, they do not know why. It started immediately with a boost.
Any ideas?
My thoughts are the car has had problems remembering seat settings and thus there may be a problem in the control module or the key came in contact with something that deprogrammed it.
TIA :confused:
Old Sep 4, 2003 | 08:14 PM
dubya's Avatar
dubya
St. Jude Contributor
Default Re: Key, Remote Lock, Seat Memory Issues (barondw)
Sounds alot like a wiring harness issue. Good luck and keep us posted. :lurk:
Old Sep 4, 2003 | 09:21 PM
slong's Avatar
slong
Very interesting. Can't wait to heir what the dealer finds, even if they do. :skep:
Old Sep 5, 2003 | 01:01 PM
barondw's Avatar
barondw
Default Re: Key, Remote Lock, Seat Memory Issues (slong)
Surprise, the dealer found nothing and Technical Support can't understand how it could happen.
BTW Lexus had similar problems and put out a TSB in 1999 warning about allowing their key to be located near any other similar type device. Also they warn about the key ring itself being in contact with the key, plastic covering, when trying to start the car.
:cool:
To Key, Remote Lock, Seat Memory Issues
