[Z06] Getting lean code with new airbridge...
Old Sep 8, 2003 | 02:37 PM
intofx's Avatar
intofx
Default Getting lean code with new airbridge...
Installed an after market airbridge with my vararam and got P0174 code. I checked all connections, reset the DIC and the code has not returned. Should I assume the car has learned about the additional air? Should I get the car tuned? Am I okay as long as the code does not return?
Matt
Old Sep 8, 2003 | 05:36 PM
SAXN8R's Avatar
SAXN8R
Default Re: Getting lean code with new airbridge... (intofx)
I would double check all your connections and make sure you don't have a leak. If you are confident there are no leaks and the code doesn't come back, I'd say you are okay! :thumbs:
Old Sep 9, 2003 | 02:05 AM
intofx's Avatar
intofx
Default Re: Getting lean code with new airbridge... (rbartick)
I like the way it looks. The red airbridge matches the FRC's. If the post asked how much hp am I getting and should I keep it on, your response would be appropriate. That said, SHOULD I WORRY ABOUT THE CODE?
Old Sep 9, 2003 | 02:51 AM
MongoosC5's Avatar
MongoosC5
Id say dont worry about it to much unless it becomes reoccuring. Also, Id recommend going to a dyno with a wide band a/f meter, tell them whats going on and get it measured. I think the computer will learn the new numbers, but better safe than broken. :cheers:
Old Sep 9, 2003 | 05:53 AM
lowdowndirty's Avatar
lowdowndirty
Default Re: Getting lean code with new airbridge... (MongoosC5)
Don't waste your money w/ the dyno if your code doesn't return. I guess you could dyno if you absolutely had to know hp/tq.
Old Sep 9, 2003 | 08:11 AM
dubya's Avatar
dubya
St. Jude Contributor
Default Re: Getting lean code with new airbridge... (SAXN8R)
I've never heard it called an air bridge and maybe I'm on the wrong part of the engine, but your MAFS might need to be cleaned.
Hope this helps.
Old Sep 10, 2003 | 12:11 AM
427CPE's Avatar
427CPE
It shouldn't have to learn how to meter air, but it does have to adapt to it. According to Vararam, its a good idea to d/c the neg batt cable for 30+ mins to allow the computer to start it's adaptive learning from a clean slate. I did this and I noticed a slightly improved performance.
To Getting lean code with new airbridge...
