[Z06] Best tire?
Old Sep 11, 2003 | 02:18 PM
ManyToyz's Avatar
ManyToyz
Cruising
Default Best tire?
I'm having trouble hooking up and need some advice on aftermarket tires. Should I go with stock size drag radial or should I just get some bigger meats? I have a friend with a 03 KB Cobra who is putting down about the same HP as my 6 and he's walking me pretty much right from the start. He's running some BFG drag radials will these ruin my handling? I like to do more that go straight. PS- for the guys who race watch those kb cobras...fast as hell! :crazy:
Old Sep 11, 2003 | 03:21 PM
jackmott's Avatar
jackmott
Default Re: Best tire? (ManyToyz)
most of the drag radials handle just fine. They are a soft compound, and when inflate to normal pressures work great for handling.
unless you often go through sweepers on the street 3 wide with a ferrari on one side and a lotus on the other I think youll do ok.
Old Sep 12, 2003 | 12:22 AM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Both BFG & Nitto have stock 18 size drags that will work fine.
Old Sep 12, 2003 | 01:09 AM
Shag Finger's Avatar
Shag Finger
Default Re: Best tire? (jackmott)
I have run DRs on the street and they are far from the same as a normal tire for handling, not only do they have a soft tread, they have a soft sidewall and will be very spongy at speed especially on a highway. They are OK for driving too and from the track, but I would not recommend them for every day tires.
To Best tire?
