[Z06] Coolant Leak
Old Sep 17, 2003 | 10:42 PM
Shylor's Avatar
Shylor
Default Coolant Leak
Can you believe this, my 2003 Z06 only has 250 miles on it and already has a coolant leak at the hose connection near the coolant tank. It's not spraying out but slowly bubbling out when the car is up to temperature. I noticed GM used a clamp that you can't tighten (unlike the C4's). So now I wondering how to fix it, without taking it to a dealership.
Old Sep 18, 2003 | 04:10 PM
Cool Ryd's Avatar
Cool Ryd
Default Re: Coolant Leak (Shylor)
:cool: :steering: Sounds like warranty work to me! Find a GOOD dealer. :cheers:
Old Sep 18, 2003 | 07:42 PM
Shylor's Avatar
Shylor
Default Re: Coolant Leak (Cool Ryd)
As I said I DON'T want to take my car to the dealership for small things as this. They always find a way to make it worse or scratch something.
Old Sep 18, 2003 | 09:51 PM
Shylor's Avatar
Shylor
Upon closer inspection today, I also notice the bottom hose in the coolant tank has a very slight leak. I was able to get the top hose to stop leaking but if I wiggled the hose the coolant would leak.
Is this GM Corvette quality? Anyone else have coolant leaks?
Old Sep 18, 2003 | 10:13 PM
Nitrodamus's Avatar
Nitrodamus
I not sure , but I think this is the first time I've heard of a coolant leak. If I understand you correctly, it not on the radiator, its on the coolant (white plastic) overflow tank. If it's on the coolant overflow tank it's most likely some plastic flashing not removed when the hose was pressed on. Either way you should take it in, the engine likes its coolant!! :seeya
Old Sep 18, 2003 | 10:19 PM
Shylor's Avatar
Shylor
Default Re: Coolant Leak (NEXEX)
It's a very minor leak, er leaks. Almost as if the clamps aren't strong enough or on incorrectly. I will try to post a picture.
[Modified by Shylor, 1:28 AM 9/22/2003]
Old Sep 18, 2003 | 10:33 PM
Shylor's Avatar
Shylor
Here are the pictures:
[Modified by Shylor, 7:50 PM 9/18/2003]
Old Sep 18, 2003 | 10:49 PM
slong's Avatar
slong
If cracked spend your money, GM will love you. If it's just the one time use clamp, spend your money, GM will still love you. :lolg:
Old Sep 18, 2003 | 10:59 PM
Shylor's Avatar
Shylor
Default Re: Coolant Leak (slong)
I have no love for dealership with regards to repairs. The last time I took another vehicle in they had to replace a radiator under warranty. When I went to pick it up I noticed they forgot to replace several bolts, scratched the top crossmember and scuffed the side door. And that was on a brand new car! I was hot about it. While they did offer to correct things, all I let them do was to put the bolts back in.
Dealerhip service....Grrrrrr!
Old Sep 18, 2003 | 11:17 PM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
If you don't want to take the car in you will need to drain the recovery tank and remove the clamps & hoses. Inspect for damage. If no damage found reinstall the hoses using regular worm-screw hose clamps. Refill the recovery tank with DexCool.
Old Sep 19, 2003 | 12:18 AM
Shylor's Avatar
Shylor
Ticks me off that I have have had 2 new cars in the last several years and now both had coolant leaks from day one.
Old Sep 19, 2003 | 05:25 PM
slong's Avatar
slong
I apologize for your troubles with your Z06. Put the clamp on; see if that fixes the leak. If it does not, remove the recovery tank like rbartick suggested and go from there. Good luck.
Old Sep 19, 2003 | 05:59 PM
Shylor's Avatar
Shylor
Thanks for your help, I'll give it a try.
To Coolant Leak
