[Z06] replacing wheel locks
Old Sep 25, 2003 | 12:54 AM
Nfuego01's Avatar
Nfuego01
Default replacing wheel locks
Anyone ever had to replace their Z06 wheel locks? I took my '02 to the dealer to have them inspect a slow leak in the right rear tire and they couldn't find the wheel lock key. After consulting the manual, which stated that wheel lock key could be found in a depression under carpet in left side of trunk, no key could be found. My question is: how many different keys are there and how does one go about replacing key? i.e can wheel locks be tracked by VIN # NOTE: I am second owner, but first owner never used wheel lock either...maybe factory screw up?
Old Sep 25, 2003 | 04:36 AM
gmblack3's Avatar
gmblack3
Default Re: replacing wheel locks (Nfuego01)
When I first got my z06 back in late 01 it was used and did not have the key either. I went to a dealer and they made all kinds of calls. No luck. So I took a 19mm 12 point socket and beat it on to each lock. I removed them all and replaced them with stock lugnuts.
Old Sep 25, 2003 | 06:30 AM
Shylor's Avatar
Shylor
You mean to say you never looked for your wheel locks long before this? Every car I've ever bought (used or new), I checked and made sure it came with what is was supposed to have.
To replacing wheel locks
