I was just taking a look at this new gtech comp model and was wondering if any of you guys have ever used it and how accurate you felt it was. It doesn't seem like such a bad unit but you never know. Thanks in advance :seeya
It is pretty accurate assuming everything is correct when you use it.
I get 0-60's in 4.3 seconds on average, and get low 2 second 60".
I took it to the track with my friend, and we tested it on his Type-R. We tested it it 4 times, and each time it was .05-.1 seconds off in the 1/4, so assuming you are on a perfectly flat surface and want to test the 1/4, it is pretty accurate.
