[Z06] Problems with Active Handling
Old Sep 29, 2003 | 02:58 PM
95jersey's Avatar
95jersey
Default Problems with Active Handling
I have an 01 Z, and have done about 5 track events this summer...I have now noticed that just about everytime I use the car (1 a week), it goes into emergency mode, and asks me to service the active handling. I always turn it off at the track and now I have to turn it off evertime I drive the car...but, the message is still coming on. Is this a common problem? It has become VERY annoying. My dealer originally blamed the problem on a bad ground. Does anyone have any ideas?
Old Sep 29, 2003 | 04:51 PM
KCvetteowner's Avatar
KCvetteowner
Default Re: Problems with Active Handling (95jersey)
Have you checked your codes? There should be one or more codes which may give you a hint as to the problem area. How's your brake fluid? You should have the car serviced asap because you don't want the system to fail on you when you need it the most....
Old Sep 29, 2003 | 04:54 PM
95jersey's Avatar
95jersey
Default Re: Problems with Active Handling (KCvetteowner)
no, I haven't checked the codes...but I don't think it has anything to do with the brakes. It's going back to the dealer tonight.
To Problems with Active Handling
