[Z06] Check Engine Light on 04 Z06
Old Oct 13, 2003 | 01:04 PM
JoeyNigs's Avatar
JoeyNigs
Default Check Engine Light on 04 Z06
409 miles and the check engine light comes on and stays on ! Belts good, Oil pressure fine, Alt putting out. No leaks, Coolant fine. Anyone encounter this problem with such low miles ? If so can you please advise what the problem was. Thanks Joey :steering:
[Modified by JoeyNigs, 6:05 PM 10/13/2003]
Old Oct 13, 2003 | 01:45 PM
ettevroc3002's Avatar
ettevroc3002
Default Re: Check Engine Light on 04 Z06 (JoeyNigs)
...You probably thought of it but, is the fuel cap on tight?
Old Oct 13, 2003 | 01:51 PM
JoeyNigs's Avatar
JoeyNigs
Default Re: Check Engine Light on 04 Z06 (ettevroc3002)
Actually i didn`t think of it, but i always fuel my own vehicle, and tighten cap good. I`ll check anyway. Has this happened to you ?
Old Oct 13, 2003 | 01:55 PM
ettevroc3002
...Had it happen a couple of months ago - remember 3 clicks.
Old Oct 13, 2003 | 06:59 PM
GasmanZR1's Avatar
GasmanZR1
Is it stock? I had the same thing happen on mine after I put on the Blackwing. When I checked the codes, I was getting lean bank history codes. After I cleared the code the check engine light went away. This happened a few times, mainly during the Spring, and hasn't happened in a few thousand miles over the Summer.
Michael
Old Oct 13, 2003 | 07:14 PM
JoeyNigs's Avatar
JoeyNigs
Default Re: Check Engine Light on 04 Z06 (gasman29)
Thanks Michael, The car is stock. I didn`t clear any codes yet, but had a 10 PCM 1 Code readiing and a 28 TCS 1 code, and several history codes.I don`t know at this time what the reference for these codes are. Do you remember the lean bank history codes ? Thanks Joey
Old Oct 13, 2003 | 08:24 PM
GasmanZR1's Avatar
GasmanZR1
P0171 and P0174 are the lean bank codes
Old Oct 13, 2003 | 09:47 PM
JoeyNigs's Avatar
JoeyNigs
Thanks again. How can i get info as to cross referencing the meaning of the numerical codes ?
Old Oct 14, 2003 | 07:24 PM
VNAMVET's Avatar
VNAMVET
Veteran: Marine Corps
Search mode..................thats how I found the meaning of my codes, for my 02 ZO6. Had a lean condition and traced it to a loose clamp on my HallTech Tric..... :yesnod:
Old Oct 17, 2003 | 10:16 PM
BIG LAW MAN's Avatar
BIG LAW MAN
I threw a code last week and it turned out to be a fuel evap sensor. I cleared it and it has not returned. Don't know what caused it because I always shut the car off when refueling and always tighten the cap.
Old Oct 17, 2003 | 10:45 PM
slong's Avatar
slong
Go here my friend.
http://www.stengel.net/diccodes.htm
:cheers:
Old Oct 19, 2003 | 12:16 AM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Re: Check Engine Light on 04 Z06 (slong)
How do you check the codes? How do you clear them?
:cheers:
Old Oct 19, 2003 | 10:35 AM
GasmanZR1's Avatar
GasmanZR1
Default Re: Check Engine Light on 04 Z06 (lager99)
See slong's post above.
Old Oct 19, 2003 | 11:09 AM
2ndVette's Avatar
2ndVette
you will have many, many codes over the life of your Vette. 99% will be absolutely non meaningful. Notate the code, clear the code and drive. If it becomes persistent over time, then start to worry.
Old Oct 19, 2003 | 11:37 AM
lager99's Avatar
lager99
St. Jude Donor '06
Default Re: Check Engine Light on 04 Z06 (2ndVette)
Thanks guys. :cheers: Other than the history codes I have 2 others:
P0420 H C
P0430 H C
Does the "C" mean that's the code setting off the light right now? What is the "TWC system"?
:confused:
Old Oct 19, 2003 | 11:50 AM
lager99's Avatar
lager99
St. Jude Donor '06
I reset it, it's probably from the cats. I'd still like to know what the code is though. Thanks for posting that link. :seeya
Old Oct 20, 2003 | 12:25 AM
mrpc12's Avatar
mrpc12
2nd Gear
Mine came on on the way home from the dealer with 30 miles on the odometer. It was the O2 sensor that was replaced by the dealer the next day.
To Check Engine Light on 04 Z06
