[Z06] launch rpm
Old Oct 30, 2003 | 12:18 PM
DAKING's Avatar
DAKING
Default launch rpm
The local strip is allowing time trials and grudge matches this week and next so I'm thinking of going out there. I have been away from this for awhile so it will be a little tricky for me. I have a 02 z06 what should I try to launch at? I had a 01 and tried 2600 it seemed a bit much Car is stock. :chevy
Old Oct 30, 2003 | 04:36 PM
RyanC7's Avatar
RyanC7
Default Re: launch rpm (DAKING)
might get a better response in the drag racing section.....
also depends on tires.... radials?
:seeya
Old Oct 30, 2003 | 09:25 PM
Bill Dearborn's Avatar
Bill Dearborn
When I am autocrossing I try to keep the rpms between 2000 and 2200 on a warm day with good tires. With the cold weather in up state New York last Saturday I had to drop down to 1500 and was still getting excessive wheel spin.
Bill
Old Oct 31, 2003 | 12:26 AM
J-Rod's Avatar
J-Rod
Default Re: launch rpm (Bill Dearborn)
This is long, but may give you some insight.
http://www.ls1tech.com/forums/showthread.php?t=108201
To launch rpm
