[Z06] Garage build update....
Old Nov 7, 2003 | 08:03 AM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Default Garage build update....
Hi Folks -
I applied the color coat of my UCoat-it UFleckAF kit over the last few days -
Here are a couple of pics -
Here is a link to a site with all of my posted garage pictures to date:
http://www.angelfire.com/ill/mqqn/garage.html
It came out pretty good it think. It is beige with the "heritage" flakes (fleck).
The total for this floor will be right at $750 (approx $1 a square foot).
Here is a link to UCoat-it for anyone that is interested:http://www.ucoatit.com/mainprod.html
The garage is complete outside except for the gutters - the siding is done.
The plumber is coming out today to run the gas and water lines and install the water heater and floor pump/manifold.
I received my lift from Autolifters and unloaded it into the "old" garage to wait until the new one is completed.
All that is left is the electrical and the drywall/finishing - and the slab in front.
In other words , the mod parties are about to begin!!!
Best Regards -
mqqn
[Modified by mqqn, 10:55 AM 11/7/2003]
Old Nov 7, 2003 | 08:42 AM
NoMercy's Avatar
NoMercy
Default Re: Garage build update.... (mqqn)
Looks great!! My next project is to get my garage spiffed up. :cool:
Old Nov 7, 2003 | 12:44 PM
wamara's Avatar
wamara
Cruise-In II Veteran
Woohoo !! Lookin good Andy. It looks like they built a loft area at the back ?? I'll be first in line at the mods party to get my straight pipes on the Z :D :cheers: :cheers: :cheers:
Old Nov 7, 2003 | 01:57 PM
mqqn's Avatar
mqqn
Cruise-In V Veteran
Default Re: Garage build update.... (wamara)
Hi Wayne -
The rear loft will not be open - it really doesn't have much room in it - but the front one will have an access panel so I can stash stuff (but that is what the other side of the garage will be for...)
The plumber is there today - hot and cold water (softened of course), and the gas lines / water heater installed today.
I am also converting to natural gas today - goodbye LP tank...
I have you down for the first official mod - but you gotta help set up the lift...
best regards -
mqqn
Old Nov 7, 2003 | 02:48 PM
wamara's Avatar
wamara
Fair enough - let me know when you're ready to install it !!
Old Nov 7, 2003 | 02:59 PM
IMA Z06's Avatar
IMA Z06
Lookin Great...............
Old Nov 7, 2003 | 06:40 PM
TRAYC7's Avatar
TRAYC7
NCM Ambassador
CI-3-4, 9 & 10 Car Show Winner
CI-3-4-5-6-7-8-9-10 Veteran
St. Jude Donor '04-'05-'06-'07-'08-'09-'10,'14, '16
St Jude Fedex Bowl Donor '09
:thumbs: :thumbs:
Old Nov 9, 2003 | 08:39 AM
Sun King's Avatar
Sun King
Default Re: Garage build update.... (Traceys2vettes)
Nice lookin' floor! :thumbs: Did you do it yourself? How much of an azz-ache was it? :cheers:
Old Nov 9, 2003 | 10:28 AM
Gene@FredBeans's Avatar
Gene@FredBeans
What a beautiful garage! When we moved into our new house last year I painted the floor the gray color. I didn't put in the little speckles. I didn't like them, but I like the look on your floor. I as afraid I wouldn't space them properly and it wouldn't look good. Your floor looks great.
After going through a winter and everything our floor looks great still but in a couple places it has blistered because of the hot tires. I've seen a new formula out there that resists hot sticky tires. Does yours resist hot sticky tires?
I used the Rust-Oleum think in a kit, with the floor bleaching stuff and all.
Gene
Old Nov 9, 2003 | 10:59 AM
mqqn's Avatar
mqqn
Cruise-In V Veteran
Default Re: Garage build update.... (Gene@FredBeans)
Hi Sun King and Gene -
Sun King - The floor was easy to apply - since I do not have drywall yet, I did not have to tape around the bottom and I could be "sloppy" in my application technique as the finish work on the walls wil take car of that.
I had to go over the floor twice with muratic acid solution, scrubbing it with a stiff floor broom.
Then I flushed the floor with lots of water to clean up the acid residue.
There are three separate coats applied -
The first coat is just for bonding - it is a three solution mix (base, activator and bonding solution. It rolls on great - if the temperature is in the low 70's.
The second coat is just the color coat and activator - you roll out an area, and then throw the flecks up in the air to "snow" down. The flakes stick to the color coat.
The final coat is ust a gloss - it needs ketone to clean up, the first two were water based...I am heating up the garage or the final coat as I type this...
Bottom line, it was fairly easy to apply to brand new 'crete.
Gene - The UCoatIt kit is warranteed for life against hot tire pickup and blistering etc...we shall see. They do state that you should not burn your tires while on the coating...
The Rustoleum was a lot less pricey - the UCoatit was right at $750 for my garage and the application is a bit more involved than the R-Oleum.
We will all know soon my floor holds up - I am going to LIVE in that garage... :lol: :thumbs: :cheers:
best regards -
mqqn
[Modified by mqqn, 10:01 AM 11/9/2003]
Old Nov 10, 2003 | 07:03 PM
Gene@FredBeans
Very nice setup all together. Keep us updated!
Gene
Old Nov 11, 2003 | 02:05 PM
RyanC7's Avatar
RyanC7
:cool: :cool: :cool:
To Garage build update....
