[Z06] lowering a ZO6
Old Nov 13, 2003 | 10:09 PM
racer959's Avatar
racer959
Default lowering a ZO6
How do you guys lower your ZO6, is it complicated to do, and which is the best way to do it, thank you :confused: :auto:
Old Nov 13, 2003 | 10:29 PM
vettethret's Avatar
vettethret
Default Re: lowering a ZO6 (racer959)
If you want it SLAMMED, coil overs. I have rippies set going on next week with 19/20" motorsport wheels. :party:
Old Nov 13, 2003 | 11:46 PM
ALLKAR's Avatar
ALLKAR
Senior Member
Cruise-In V Veteran
Look under "TOOLS" "TECH TIPS" "LOWER YOUR Z06"
Lots of INFO there!! :thumbs:
Old Nov 14, 2003 | 12:44 AM
ActionZ06's Avatar
ActionZ06
Default Re: lowering a ZO6 (ALLKAR)
In another forum someone said how they lowered their Z06 for no cost, how is that done?
Old Nov 14, 2003 | 12:51 AM
ALLKAR's Avatar
ALLKAR
Senior Member
Cruise-In V Veteran
Default Re: lowering a ZO6 (ActionZ06)
Did mine for $0.00 Still have to get an alignment though!
Look at my last post!!
Old Nov 14, 2003 | 01:02 AM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Here is one method. http://www.members.shaw.ca/superchargedvette/Tips.htm
Total cost $0. If you want to go lower than this way, get longer bolts 6 1/2"- 7" x 1/2" (or 9/16" if you can find them). On the front, cut 2/3 of the rubber bushing off. It will make sense if you look at the link provided first. Total cost of second option, $5-$10. :cheers:
Old Nov 15, 2003 | 01:35 PM
Travis99C5's Avatar
Travis99C5
Default Re: lowering a ZO6 (Racer44)
Even if you lower it as low as stock will go, it still looks high. I am considering doing it the other way where you get the longer bolts. I still look like a high roller :) hehe
More pics here:
http://www.badassride.com/images/Scr...-Dry_Lake_Bed/
Old Nov 15, 2003 | 08:11 PM
Vegasr's Avatar
Vegasr
To align or not to align, that is the "on going" question.
I lowered mine 6 months ago, to factory limits, and did not align. I have not seen any uneven wear on any of the tires. :confused: :confused:
To lowering a ZO6
