My Z06 has about 6000 miles on it and is making a clicking noise in the rear end when accelerating and deaccelerating, especially when cold. Is this normal or do I have a loose sway bar or shock or something?
Re: Clicking or Knocking in Rear End (JeffFWCvette)
My car was making that noise whenever I would change from accelerating to decelerating, or when going over large bumps. I decided to check all the rear suspension bolts for tightness myself. I found the upper shock mount bolts to be loose - factory mistake. I tightened them up, and problem solved! I've heard other C5's have left the factory with these bolts loose too, so I would check 'em! They're easy to get at and easy to tighten, so I wouldn't even bother with a dealer if you're decent with a wrench.
Well, I took the Vette to the dealer just in case it was something bad. They found a seal leak in the rear end, apparently a typical problem but no evidence of anything else wrong. They said they drove a couple of other Vettes and decided the noise was normal. I'm not sure I believe it is normal so I will check those upper shock mounts myself and keep an ear on the noise to see if it gets any worse. :confused:
Mine occasionally makes slight clunking noises from the right rear over uneven pavement. At least some of the noise was coming from the tire-inflation kit.
Mine makes a clicking noise as well. I can sit at a stop and ease the clutch out an "click". It's also quite pronounced when in first gear chugging along at idle. I tap the gas lightly and "click". Damn annoying, and the dealer says they can't find anything wrong with it.
Seems to me it's got to be a u-joint or something similar. I'll check underneath for loose bolts before I take it back to the dealer. It's driving me nuts!
