[Z06] Z06 diff year to year?
Considering to get a used 2002 or a new Z06 (do they go for close to invoice now?).
What are the differences year to year of the Z06.
2002 and up all have HUD, right?
Do they have telescoping steering column if the memory package is added?
And I seem to recall that the Z06 suspension (shocks and sway bars) got tuned almost every year, right?
If so, was if for the better for AutoX?
Also, with the Black/Red interior option, the floor mats and trunk mat are still black, right?
Thanks,
-kg
[Modified by KGjevre, 12:54 PM 11/20/2003]
2002 405 hp
2004 new shocks just great put them on my 2000 coupe ! :yesnod:
This is most of it. Not too much . . .
-Diamond mentioned HUD standard beginning 2002.
-Unfortunately for us tall ones, a head impact was added in the ceiling of 2003 and 2004
-Rear shocks were re-valved for "a more controlled ride" . . . Whatever that means
-Rear leaf spring stiffened
-Front stabilizer larger
-Different factory camber alignment settings
-Wheels are the same . . . but different alloy.
-Break pads are different for "improved fade resistance"
-Aluminum front stabilizer bar links
-New higher lift cam shaft
-Hollow stem valves
-Higher tension valve springs
-Different lower restriction mass airflow sensor
-Different lower restriction airbox
-Different fuel and spark programming curves
-Different piston rings to fix oil consumption problem
-Different pistons coated with a special polymer to fix cold knock problem
-Different exhaust system with no "pup" cat on the down tubes. Less restriction and 5.5lbs weight loss.
-Different clutch and pressure plate jumps clamp load 7 percent to 2475 lbs
You'll find most of the details here: http://www.c5registry.com/2k2z06/
[Modified by JimAgain, 9:20 PM 11/19/2003]
Since I am 6'3" and add an inch or so with a helmet for AutoX, there is actually an incentive for me to look for a used low-mileage 2002 - we will see.
-kg
A dealer's sales person that called me as a response to an inquiry I did through Edmunds offered $2000 or $3000 off MSRP, but "he was only allowed to do this internet discount on 2 more cars", but may be able to do better when I come in... they only had silver and red Z06 and I think I want yellow though...which I located at another dealer...may stop by there on the weekend...
-kg
[Modified by KGjevre, 12:55 PM 11/20/2003]
Thanks, very good info.
I am not in a rush, so I could even wait until January and see what happens when the C6 is introduced, but not sure if this will affect supply of 2004 Z06.
-kg
