[Z06] Oil Filter Opinions
Old Nov 22, 2003 | 02:48 PM
JoeyNigs's Avatar
JoeyNigs
Default Oil Filter Opinions
Just curious as to what other members consider the best Oil Filter manufactured on the market today ?
Old Nov 22, 2003 | 03:03 PM
BLU-BY-U's Avatar
BLU-BY-U
Default Re: Oil Filter Opinions (JoeyNigs)
the k&n is suppose to be excellent.
Old Nov 22, 2003 | 04:26 PM
C5Longhorn's Avatar
C5Longhorn
Default Re: Oil Filter Opinions (BLU-BY-U)
For a premium oil filter, I use the UPF44. I think all the premium filters are very good and would probably work well.
Old Nov 22, 2003 | 07:39 PM
ZO6Les's Avatar
ZO6Les
Default Re: Oil Filter Opinions (C5Longhorn)
:iagree: UPF, K&N or Mobil 1 - I personally use the Mobil 1.
Les :cheers:
Old Nov 22, 2003 | 08:16 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
OEM is the best I saw a bunch cut in half and some are jokes!
Old Nov 22, 2003 | 08:35 PM
slong's Avatar
slong
I put this up on a different topic before. This is not the Holy Grail, but it does have some good info. Peace and Happy Turkey Day Everyone!!! :thumbs:
http://www.minimopar.net/oilfilterstudy.html
Old Nov 22, 2003 | 09:09 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi JoeyNigs -
I use the K&N.
Best Regards -
mqqn
Old Nov 23, 2003 | 07:13 AM
vector1's Avatar
vector1
7th Gear
from what i have deduced the ac, wix, and napa gold seem to be some of the better oil filters. mobil is good although it is supposed to be somewhat more restrictive, k & n and amsoil i'm sure are good but don't have any information on them to make a decision.
as for oil, mobil 1 seems to be showing a lot of iron wear on some of the analysis i have been reading expecially in regards to the ls1 motor. amsoil uses the same base stock, but they put zddp and/or moly in their oil and use higher levels of detergents from what i have gathered. it seems the amsoil analysis always come out good unless something is wrong with the engine.
also regarding air filters, k & n does flow more air, yet i believe it is also letting more dirt into the motor from the analysis i have been reading with higher silicone numbers. a lot of guys (in my opinion)are switching back to the paper elements or different type filter. not sure how the other oiled gauze filters work. i would guess donaldson makes a good one since they have so much experience in other air filtration arenas, although i don't know how their's would differ.
of course these are just my opinions (disclaimer) a good web site to make your own decision is bobistheoilguy. good luck
To Oil Filter Opinions
