[Z06] cats or no cats?
Old Nov 28, 2003 | 10:17 AM
joe03z06's Avatar
joe03z06
Default cats or no cats?
hey im getting the flp headers installed and they want to know if i want the cats or the off road set up. what do you guys recommend? they say if they r not on it takes twenty mins to swap them out for inspection. is it worth the effort and whats the power dif?
[Modified by joe03z06, 9:35 AM 11/28/2003]
Old Dec 1, 2003 | 02:53 AM
larrysb's Avatar
larrysb
Default Re: cats or no cats? (joe03z06)
Well, what do you hope to gain from not having them? Most dyno sheets don't show more than a minor improvement. There are a lot good choices today of hiflow cats and the factory ones are pretty decent. The cats help scrub a lot of bad stuff out of the exhaust.
Since you live in Sugarland, right outside of Houston (where I used to live), consider the condition of the air where you live. Think it over and ask yourself if it is worth it.
Old Dec 1, 2003 | 05:57 AM
ZO6Les's Avatar
ZO6Les
If you don;t run cats you will need to run O2 sims or LS1Edit to turn the rear O2's off. (BTW to asnwer the other post the FLP's come with hgh-flow cats)
I dyno'd my car with and without the cats, picked up 8 RWHP (same dyno, same day - all that stuff). The car will be louder without the cats, a little more smell, and will get the rear of your car dirty faster. In my case I left the cats off, some leave them on - that is one of the things I like about the FLP's - you have the option.
Les
To cats or no cats?
