[Z06] clutch pedal getting stuck?
Old Dec 3, 2003 | 04:48 PM
joe03z06's Avatar
joe03z06
Default clutch pedal getting stuck?
has neone ever had there clutch pedal stick to the floor on very hard driving? was racing a supra the other day and 2nd to 3rd my clutch pedal stuck to the floor and didnt want to come up. slowed down and pushed on it hard a couple of times and finally came up and stunk for like 15 mins. should i be worried? :confused:
Old Dec 3, 2003 | 04:49 PM
thefly's Avatar
thefly
Default Re: clutch pedal getting stuck? (joe03z06)
sounds like you smoked it a little. comes from overheating. should be fine, but you definitely shaved some life off it...
Old Dec 3, 2003 | 04:52 PM
levrac68's Avatar
levrac68
my POS stock Z06 clutch used to stick all the time when I drove it hard. I switched to the Cartek clutch and never had a problem again. :cheers:
The problem had to do with the design and the fluids getting overheated. Some other technical gurus can better elaborate on it for you.
Old Dec 3, 2003 | 05:09 PM
dubya's Avatar
dubya
St. Jude Contributor
Default Re: clutch pedal getting stuck? (levrac68)
Your tranny temp definatly got way too hot. I'm sure someone will chime in on a fix.
PS, check your fluid res for fluid. I beleive it is just brake fluid.
Good Luck
Old Dec 3, 2003 | 05:12 PM
vettezosix's Avatar
vettezosix
Are you sure you are not burning up the clutch??
Old Dec 3, 2003 | 05:22 PM
joe03z06's Avatar
joe03z06
Default Re: clutch pedal getting stuck? (vettezosix)
what do you mean burning up the cluctch?, i was just shifting hard at the redline
Old Dec 3, 2003 | 05:27 PM
mgaskins's Avatar
mgaskins
The same thing happened to me when I ran the 1/4 mile several times without cooling down. The problem went away for two reasons:
1. I got Landmark Chevrolet to replace the clutch under warranty
2. I now cool down under 200 degrees before going at it again
Old Dec 3, 2003 | 07:58 PM
ZO6Les's Avatar
ZO6Les
Yep, mine did it several times, GM replaced the entire clutch assembly and hydraulics under warranty. It is a design flaw having to do with the way the fluid is routed and how easily it gets overheated. You can improve things by sucking the fluid out of the resevoir regularly and replacing it with DOT 4/5 with a higher dry and wet boiling point. I finally went aftermarket.
Les :cheers:
Old Dec 4, 2003 | 07:52 AM
dubya's Avatar
dubya
Default Re: clutch pedal getting stuck? (ZO6Les)
Les :cheers:
Les, I was thinking of doing the same thing but was concerned because of the fluid comp of higher dot fluids. The higher dot fluid is working fine for you? How long have you been running it? Thanks
Old Dec 4, 2003 | 08:10 AM
ZO6Les's Avatar
ZO6Les
Default Re: clutch pedal getting stuck? (dubya)
All of the Z06 guys that I know around here are running higher DOT fluids (that are also DOT 3 compatable) with no problems. I have used Vavoline Synthetic DOT 4 - no problems.
Les
Old Dec 4, 2003 | 01:04 PM
pwrshhftd's Avatar
pwrshhftd
that happened to by buds 2001 z06 when i was drag racing it a while back. it got to where it did it every pass and made driving the car impossible. i just would take my toe and pop it back up to the top. he never could get the dealer to do anything with it, so he traded it in and the dealer wound up losing about 7500$ on it. sucks for them. they game him 37,500 on trade and auctionit 7 months later for 30,500. They have since jerked me around with my z06, and I had to drive 3.5 hours to Tom Jumper Chevy in ATL to get anytign done. I have no sympathy for my local dealer.
By the Way they are Franklin Chevrolet in Statesboro Ga if anyone wants to know where NOT to take their car for service.
haha
that hasnt happened to my 2002 z06 yet. it has acted a little funky on a couple of occasions, but nothing like that.....
it will get worse i predict...
[Modified by pwrshhftd, 1:08 PM 12/4/2003]
To clutch pedal getting stuck?
