[Z06] Z06 Alignment Specs needed??
The following are the alignment specs for a FE4 Corvette (Z06):
Front Individual Toe: + 0.04
Front Sum Toe: +0.08
Steering Wheel Angle: 0.0
Front Individual Caster: + 6.9
Front Cross Caster: within +/- 0.5
Front Individual Chamber: - 0.70
Front Cross Chamber: within +/- 0.5
Rear Individual Toe: -0.01
Rear Sum Toe: - 0.02
Rear Thrust Angle: 0.0
Rear Individual Camber: -0.68
Rear Cross Camber: within +/- 0.5
These specifications are taken from the 2002 Corvette Service Manual, Volume 1 of 3 - Page 3-20
I hope this helps.
http://www.corvetteactioncenter.com/...n.php?qstId=69
before and after????
i have lowerd mine, just what the factory adjustments willlet you... how bad do i need a realighnment??
thanks
rb
