[Z06] Ignition key cylinder
Old Dec 12, 2003 | 07:04 PM
Zero00's Avatar
Zero00
Default Ignition key cylinder
Do you or don't you lube the ignition key cylinder. If you do, what do you use. Thanks for your help...I've gotten confliction answers when asked. :confused:
Old Dec 12, 2003 | 07:08 PM
Zero00's Avatar
Zero00
Default Re: Ignition key cylinder (Zero00)
The computer gremlins must be at work.....I typed in "conflicting answers", not "confliction answers"........gee, I hope the heebie jeebies don't carry over to my car :lol: .
Old Dec 13, 2003 | 04:01 AM
kevette's Avatar
kevette
If you are talking about the key slot, you use electrical cleaner...can be found at about any parts store. If you are talking about the cylinder(whole) you do not, no need to!!! Did you have to replace it or something????
Old Dec 13, 2003 | 08:36 AM
Zero00's Avatar
Zero00
Default Re: Ignition key cylinder (kevette)
I'm talking about the hole where I stick my key in to start the car. What would you use? :steering:
Old Dec 13, 2003 | 03:41 PM
WWK888's Avatar
WWK888
Usually the hole where I stick my key doesnt need any lube :D :D :D
BTW, just for your info you can hit the "edit" feature to make changes to your original post instead of posting again...
:cheers:
To Ignition key cylinder
