[Z06] Z06 shift pattern migration???
Old Dec 13, 2003 | 04:05 AM
pwrshhftd's Avatar
pwrshhftd
Default Z06 shift pattern migration???
Has anyone had their shift patter migrate on a C5?
After a trip to the drag strip last week, my car all of a sudden wouldnt go into reverse very well.
It was because the shifter was runnign into the console.
After about 2 days of this... i just kind of gave the shifter a tug back towards the drivers side of the car and it seems to have fixed it...
I guess there is somethign loose in the shift linkage...
Ever heard of this??
Old Dec 13, 2003 | 10:16 AM
opticZ06's Avatar
0opticZ06
Former Vendor
Default Re: Z06 shift pattern migration??? (pwrshhftd)
Yep it is called driver ERROR, must be from you powershifting so damn hard. :yesnod:
Old Dec 13, 2003 | 02:07 PM
CHJ In Virginia's Avatar
CHJ In Virginia
The shifter mounts with a series of bolts around the flange. They could be slightly loose allowing the shifter to slip sideways with extreem use. I would open the boot etc. and check the alignment / tightness of the bolts. that should fix your problem.
Old Dec 13, 2003 | 02:25 PM
Painrace's Avatar
Painrace
A few bolts are lose. You Chevy dealer should have no problem in helping or get the instructions to change the shifter and you will see what to do.
Old Dec 13, 2003 | 05:52 PM
Steve Row's Avatar
Steve Row
Cruise-In II Veteran
Cruise-In III Veteran
Mine moved enough that it would not stay in 2nd, 4th or 6th. This was with a Hurst shifter and powershifting.
On the stock shifter there is a neutral pin on the front of the base. It sits in a hole there waiting to be used. You use it by putting the shifter in neutral and inserting the pin in another hole which should line up with a hole in the shift shaft. This shaft is the pieced which has the hole in it for the shifter and is not removed or changed when installing an aftermarket shifter. On the rear of this shaft is an adjustment where it is clamped to the rod that goes back to the transmission. If the neatral pin does not line up properly, loosen the clamp, insert the neutral pin and tighten the clamp good and tight.
This adjustment cured the popping out of gear problem, but not the trashed syncro's.
There also could be worn pads on the shift forks and/or worn shift forks. The steel shift fork goes a long way to cure this problem.
Check out this link for pictures of my transmission rebuild.
http://temp.corvetteforum.net/c5/steve_row/index.shtml
Good luck.
To Z06 shift pattern migration???
