[Z06] Wheel HOP!
Old Dec 18, 2003 | 06:17 AM
Rob's 73's Avatar
Rob's 73
Default Wheel HOP!
My car gets the hops when I light them up in first or second. What can I do to get rid of it.
Old Dec 18, 2003 | 07:37 AM
StickTail's Avatar
StickTail
Default Re: Wheel HOP! (Rob's 73)
They will tend to do that in this cold weather.
Try feathering the clutch a bit.
Old Dec 18, 2003 | 07:54 AM
varkwso's Avatar
varkwso
I reduced the RPM when I hammered it and improved my 60' times and reduced HOP to almost nil...I launch at 1800-2100 RPM on the F1s. On other cars I launch at a much higher rpm.
Old Dec 18, 2003 | 09:06 AM
ZO6Les's Avatar
ZO6Les
1. Feather the clutch, play with tire pressures
2. Have alignment checked
3. Install polyurethene bushings in rear suspension parts
I have been drag racing for MANY years, had wheel hop fo bad in this car when I bought it that the driver abuse algorithm would re-engage traction control on launch, as well as the 1-2 ans 2-3 shift. Some cars have it worse than others, mine had it very bad. For me the poly "U" bushings took care of 90% of it, and items (1) and (2) the rest.
Do a search, this topic has some other ideas as well.
Les
Old Dec 18, 2003 | 12:02 PM
mikeo's Avatar
mikeo
Default Re: Wheel HOP! (ZO6Les)
Please forgive me. I'm a nubie. Can someone please explain what is meant by "feathering the clutch." Thanks.
Old Dec 18, 2003 | 12:16 PM
ZO6Les's Avatar
ZO6Les
Default Re: Wheel HOP! (mikeo)
Wheel hop is when available traction exceeds the suspensions ability to keep the tire "planted" on the pavement. The suspension flexes up and down as the tire skips along the pavement.
"Feathering" the clutch means to release it more slowly when shifting hard. and by modulating the fun pedal and clutch you get to a happy medium of maximum accelleration with minimal wheel hop. Like I said, some cars seem to have it worse than others, and exceptional drivers like Ranger manage excellent times by modulating the clutch as described. I am not that good apparently so I fixed it by putting in the poly u bushings, which "flex" much less than stock. Some have fixed less severe wheel hop problems with a good alignment, some with different shocks. No one cure fits all.
Hope this helps.
Les
Old Dec 18, 2003 | 12:58 PM
Rob's 73's Avatar
Rob's 73
Thanks for the quick input.
So, I assume the hop is caused by the intial (shock) load put upon the suspension when you dump the clutch. I had the problem nailing it from a 10 mph roll with the clutch out as well. Weather was cold.
[Modified by Rob's 73, 1:26 PM 12/18/2003]
Old Dec 18, 2003 | 01:10 PM
mikeo's Avatar
mikeo
Z06Les: Thanks for the info. Please, one last question. A couple days ago I posted a question about whether the poly u bushings were worth the cost. The responses I got back were not that favorable. Do you disagree? Thanks.
Old Dec 18, 2003 | 01:22 PM
zo6fun's Avatar
zo6fun
You guys forgot one thing...
get smaller rims and put on some Goodyear Eagle STs...
:lol: :lol: :lol: :lol: :lol:
can you say "pile of rubber"?
:D
Old Dec 18, 2003 | 03:48 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
I only had wheel hop the first time I tracked my Z. I determined I can't power shift 1-2. Since I stopped that, I haven't had wheel hop since!! :flag :thumbs:
Old Dec 18, 2003 | 04:22 PM
ZO6Les's Avatar
ZO6Les
IMO the poly U bushings are an excellent mod, well worth the money, but try the alignment and tire pressure tricks first.
Les
Old Dec 18, 2003 | 04:30 PM
mikeo's Avatar
mikeo
Thanks Les.
Old Dec 18, 2003 | 11:23 PM
BlazeSkywalker7's Avatar
BlazeSkywalker7
will lowering the car reduce wheel hop?
Old Dec 19, 2003 | 03:28 AM
IsItFast's Avatar
IsItFast
Default Re: Wheel HOP! (BlazeSkywalker7)
This car doesn't wheel hop compared to my 99 Cobra; it had it bad.
Old Dec 19, 2003 | 04:45 PM
ZO6Les's Avatar
ZO6Les
Some say it does, it definitely changes the travel action of the shocks, so in theory it could help. Lowering the car had no affect on my wheel hop, one way or the other.
Les :cheers:
To Wheel HOP!
