[Z06] Kink in Driver Door
Old Dec 25, 2003 | 09:51 PM
theblackvette's Avatar
theblackvette
Default Kink in Driver Door
I have noticed then when I close the Driver door from the totally opened position I feel a "kink" upon closing. Not the normal smooth closing that is felt with the passenger side door. Could it be a faulty hinge or something? It is pretty annoying and is there an easy way to fix it? Thanks!
Old Dec 26, 2003 | 12:31 AM
slong's Avatar
slong
Default Re: Kink in Driver Door (theblackvette)
There is a spring loaded arm by the hinges that keeps the door from closing on your leg. Mine was exactly the same. Spray some lube and it will be cured, if that is the problem.
Old Dec 26, 2003 | 06:16 AM
theblackvette
Default Re: Kink in Driver Door (slong)
Thanks-is it safe to assume this spray "lube" would be AKA as WD-40?????
Thanks!
[Modified by theblackvette, 11:39 AM 12/26/2003]
Old Dec 26, 2003 | 08:33 AM
CYA-Vett's Avatar
CYA-Vett
Just be careful with the amount of lube you spray in there, I sprayed a bunch of lube in one of my other cars and the inside of the car smelled like lube for weeks! Yuck!
Old Dec 26, 2003 | 10:28 AM
Z_OH_6's Avatar
Z_OH_6
slong wrote: "There is a spring loaded arm by the hinges that keeps the door from closing on your leg."
:iagree: The detent seems to be only on the driver's side door. :)
Old Dec 26, 2003 | 11:46 AM
slong's Avatar
slong
Default Re: Kink in Driver Door (Z_OH_6)
Hey Z_OH_6,
Must be really nice up your way about right now. Is there to much white stuff to drive the Vette around?
Have a nice holiday,
slong
Old Dec 26, 2003 | 02:16 PM
theblackvette
I sprayed the lube and it appears to have helped! Thanks!!!!!!!
:thumbs:
Old Dec 26, 2003 | 03:21 PM
sliderhss's Avatar
sliderhss
I have the same problem only on the passenger side. I will spray something on it to see if it fixes the problem.
Old Dec 26, 2003 | 03:41 PM
Geneus's Avatar
Geneus
:thumbs:
Had the same thing happen with my driver side door. I sprayed white lithium grease and problem solved. :)
To Kink in Driver Door
