[Z06] Door lock problem
Old Jan 12, 2004 | 06:38 PM
RonH's Avatar
RonH
Default Door lock problem
Driver side door will not unlock with the key fob or with the unlock button. I have to open passenger door and reach through. Has anyone had this problem and is there an easy solution. Warranty out last November on my 01 Z06.
Old Jan 12, 2004 | 08:17 PM
HummelS's Avatar
HummelS
Default Re: Door lock problem (RonH)
Probably the door control module - they are pretty notorious for failure.
Old Jan 13, 2004 | 12:05 PM
RonH's Avatar
RonH
Default Re: Door lock problem (thevettenet CA)
Is this something which I can do or should I take to dealer? Is it located inside the door panel or elsewhere?
Old Jan 13, 2004 | 03:39 PM
Z06_2002's Avatar
Z06_2002
Both of my corvettes did the same thing. Drives me :crazy: till I got the modules replaced.
Old Jan 13, 2004 | 04:00 PM
RonH's Avatar
RonH
Default Re: Door lock problem (Z06_2002)
Did you do this yourself or did you have to take to dealer? I am trying to determine if I can replace module myself.
Old Jan 13, 2004 | 04:30 PM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
See if there are any codes stored in the Driver Information Center.
Old Jan 14, 2004 | 12:26 AM
z06_23_45's Avatar
z06_23_45
Try to unlock it manually and then toggle the switch back and forth a couple of times and see if you can't get it to work that way. That just happened to me a couple of days ago, and that took care of my problem.
To Door lock problem
