[Z06] Exhaust Tips
Old Jan 17, 2004 | 11:06 PM
steve1173's Avatar
steve1173
Default Exhaust Tips
My 04 Z06 all 4 of the exhaust tips are at a different height, not straight accross evenly. Is this adjustable or should I just live with it.
Old Jan 17, 2004 | 11:44 PM
Z_OH_6's Avatar
Z_OH_6
Default Re: Exhaust Tips (steve1173)
Afraid they are not adjustable. If bad enough you may want to have Chevy straighten them. Congrats on the new Z. :hurray:
Old Jan 18, 2004 | 03:03 AM
pk2401's Avatar
pk2401
St. Jude Contributor
Default Re: Exhaust Tips (Z_OH_6)
:iagree: Enjoy your new Z. :cheers:
Old Jan 18, 2004 | 07:16 AM
kumar75150's Avatar
kumar75150
I can see the 2 left ones being at a different height than the 2 right ones but if they are all at different heights, go complain to the dealer. Hopefully, they will fix your problem.
[Modified by kumar75150, 6:17 AM 1/18/2004]
Old Jan 18, 2004 | 11:44 AM
Kenny94945's Avatar
Kenny94945
Steve...three options.
1 - I do not recommend....take a broom handle insert into tail pipe and bend.
2 - Highly recommend...When the muffler bolts to the exhaust flange with two bolts. Dremil tool the lower of the circular holes oblong. Install the upper bolt and then twist the muffler into alignment and re-bolt tight. You can typically reuse the gasket at the flange.
3 - Highly recommend...(and easy) The rubber muffler hanger at the rear bolting to the bumper reinforcement. You can shim this between the rubber and the rein. to adjust height on both sides as need be.
To Exhaust Tips
