[Z06] Tire size question...
Old Jan 21, 2004 | 10:42 PM
Cruises's Avatar
Cruises
Default Tire size question...
from a 2K Vert guy.
Are the tire sizes the same on both the verts and Z06's ?
I know that wheel size is not the same, but when I check Tirerack and other sites, they don't indicate separate tires for each model by tire size even though the Z06 wheels are 1" wider front and rear. :confused:
Old Jan 21, 2004 | 11:01 PM
pk2401's Avatar
pk2401
St. Jude Contributor
Default Re: Tire size question... (Cruises)
Not for sure. I use Kumho ECSTA MX. I bought them from WCC. They said they are for the Z06. He are my tire numbers so you can compare them to yours. 275/40-17 front and 295/35-18. Hope this helps. :cheers:
Old Jan 22, 2004 | 08:38 AM
Z_OH_6's Avatar
Z_OH_6
They're not the same. Convertibles come with Goodyear Eagle F1 GS Extended-Mobility tires, P245/45ZR-17 in front and P275/40ZR-18 rear. The Z06 comes with Goodyear Eagle F1 Supercar Non-Extended Mobility tires. Size P265/40ZR-17 front and P295/35ZR-18 rear. :yesnod:
Old Jan 22, 2004 | 12:15 PM
Cruises's Avatar
Cruises
Default Re: Tire size question... (Z_OH_6)
Thanks for the clarification. :cheers:
To Tire size question...
