[Z06] Removing 1 to 4 shift??
Old Jan 23, 2004 | 12:44 AM
Flotsam's Avatar
Flotsam
1st Gear
Default Removing 1 to 4 shift??
I just got my Z06 last week. The first to forth shifting is killing me. Is there an easy way to get rid of that?
Any help would be greatly appreciated.
Old Jan 23, 2004 | 02:44 AM
FlyinNOE's Avatar
FlyinNOE
Default Re: Removing 1 to 4 shift?? (Flotsam)
Congratulations on the new car.
Some guys unplug the plug from the solonoid on the transmition and use a resister to fool the computer so they don't get error codes.
I bought a "CAGS" elimonator which is basically the same thing only more expensive(about $30). I didn't know any better at the time. You can buy one at most of the vendors at this site. It's plug and play, just jack the rear end up and zip tie the now unplugged wire. You will still get the light, but you won't be locked out of 2nd.
The other way to get rid of it is to have it programed out of the computer. This routes typically a lot more expensive.
Hope this helped.
Brian :flag
Old Jan 23, 2004 | 06:29 AM
theblackvette's Avatar
theblackvette
Yeah I could not stand that 1 to 4 shift and got it removed immediately via edit!
Best thing I ever did to my Z06!
Congrats on the new car!
:party:
Old Jan 23, 2004 | 08:43 AM
Z_OH_6's Avatar
Z_OH_6
Congratulations and welcome! As they've said above, it is simple to eliminate the Computer Aided Gear Shift feature, put on by Chevy to eliminate you having to pay a gas guzzler tax. Sold by most of the vendors here for about $19-30, it is a CAGS eliminator device. Just jack up the rear, use jack stands, or as I did, back onto a couple car ramps and crawl under. The device goes on the transmission. As mentioned above, the shift light will still come on but the shift can be made at your pleasure. Not sure if the LS-1 edit removes the light. theblackvette will know. :chevy
Old Jan 23, 2004 | 10:11 AM
jerryv's Avatar
jerryv
Default Re: Removing 1 to 4 shift?? (Z_OH_6)
LS1 Edit DOES remove the light .. I think it allows you to set the conditions for activation to values that can't be reached, preventing the light from illuminating.
Personally I like seeing the light ... it reminds me that I've bypassed their stupid feature. I bought one of the CAGS defeats for about $20. They're all the same, so shop for price. If you choose to do it the Radio Shack way, use a 2.2 K ohm 1/2 watt resistor (don't use 1/4 watt).
Old Jan 23, 2004 | 10:28 AM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
One of the parameters for CAGS enable is coolant temp. The stock coolant temp value for CAGS enable is 173 degrees. If you watch a car with a stock PCM on a cold morning you will see that until the car warms up you get no CAGS bypass and no CAGS light in the dash.
My LS1Edit flash file has my CAGS enable temp set at 250 degrees. I never get the light anymore.
Old Jan 23, 2004 | 04:22 PM
theblackvette
Default Re: Removing 1 to 4 shift?? (rbartick)
That is affirmative the edit DOES indeed remove the light! I am glad it did. That was another annoying feature of the Z06.
However, I cannot confirm if a CAGS defeater installation would remove the light.
Good luck!
Old Jan 23, 2004 | 05:09 PM
RussBt's Avatar
RussBt
Default Re: Removing 1 to 4 shift?? (theblackvette)
It will not. The PCM still thinks it is enabling CAGS so the light will come on. The CAGS light will only stay off if the PCM wants the CAGS sytem disabled.
[Modified by rbartick, 5:11 PM 1/23/2004]
Old Jan 23, 2004 | 05:15 PM
theblackvette
From what I hear that if you just only want to get rid of the 1 to 4 you can get a CAGS defeat for like 30 bucks or something. The edit is much more money but you also get other goodies in addition to removing the annoyine 1 to 4.
So if you just want to get rid of the 1 to 4 with no other goodies and don't mind the light, the CAGS defeat is definitely the way to go in my opinion.
Old Jan 23, 2004 | 09:09 PM
J Lance Miller's Avatar
J Lance Miller
Hey Flotsam, welcome and congrats on your transportation choice.
2.2 K ohm 1/2 watt resistor - obtain in packs of 6 at the Radio Shack (on Louis Henna on the opposite side of the freeway from Hooters...) expect to shell out about $2.
Lance (# 425221)
Old Jan 25, 2004 | 07:11 PM
sliderhss's Avatar
sliderhss
Default Re: Removing 1 to 4 shift?? (J Lance Miller)
Best thing I ever did.. !CAGS
Old Jan 26, 2004 | 02:26 PM
fast4vette's Avatar
fast4vette
Default Re: Removing 1 to 4 shift?? (sliderhss)
since cags only kicks in when:
temp is 170+
AND
speed is 15-19mph
AND
throttle is 21% and less,
it is so easy to drive the car and not ever get caught with it.
learn to drive your car man.
:cheers:
Old Jan 26, 2004 | 02:50 PM
slong's Avatar
slong
Stop and go traffic + 1ST to 4TH sure do not mix. :lol: :cool:
Old Jan 26, 2004 | 09:25 PM
TooManyIDs's Avatar
TooManyIDs
:iagree:
I installed the bypass first. Light was still active, but shift disabled.
Later used LS1Edit, with a 325 enable. Never bothered to remove the bypass. No light.
Old Jan 26, 2004 | 10:01 PM
spdy's Avatar
spdy
I have a CAGS eliminator that I removed from my 02 Z06 (using LS1 edit now). Includes directions. I'll send it to you for $15 shipped if you want. :cheers:
Old Jan 29, 2004 | 04:40 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
Just rev it higher whenever you drive. Why waste the money. kaley
Old Jan 29, 2004 | 09:00 PM
theblackvette
Default Re: Removing 1 to 4 shift?? (fast4vette)
"Learn the drive the car?"
"Don't waste the money?"
Huh? SHIRLEY YOU CAN'T BE SERIOUS?
Hello? Like I don't want to REV my car everytime I drive! I also get caught in traffic jams and school zones. I simply don't want to be bothered with this thing. Therefore, for the price of a half of tank of gas you can get rid of this useless feature on the Corvette.
:D
[Modified by theblackvette, 2:02 AM 1/30/2004]
To Removing 1 to 4 shift??
Old Jan 31, 2004 | 07:37 PM
fast4vette's Avatar
fast4vette
this is a small window dude,
speed is 15-19mph AND throttle is 21% and less and cags kicks in.
you are a looser.
i am sorry, but i mean it.
:cheers:
Old Jan 31, 2004 | 11:56 PM
theblackvette
My friend. I hated the shift lock out so I got rid of it!
It is as simple as that.
Don't get the loser thing either............
Cya.
Old Feb 1, 2004 | 10:49 AM
slong's Avatar
slong
So everyone who has CAGS should learn to drive there Vette at the range of 15MPH to 19MPH during 21% throttle response. Now there's a value added comment. "No I don't think so" I, or we spent the $20.00 bucks so it never enters the mind again while driving. As a popular comedean once said; Here's your sign! :lol:
