[Z06] Looking for Brakes !
Old Feb 10, 2004 | 08:36 PM
BH's Avatar
BH
Default Looking for Brakes !
Wanting to put a set of brakes front and rear on my ZO6 with 18inch wheels. I will do some track events but mostly street. My wheels will not accept the Brembo's so I need some advice.
Old Feb 11, 2004 | 08:07 PM
Gene@FredBeans's Avatar
Gene@FredBeans
Default Re: Looking for Brakes ! (BH)
Go with the GM ceramic pads. We have front and rear on sale for 145.99 shipped!!
Gene
Old Feb 11, 2004 | 08:08 PM
BlackZ06's Avatar
BlackZ06
I'd recommend you first try different brake pads.
For the street I use the Hawk HPS pads ....
Front is Hawk part No. HB247.575
Rear is Hawk part No. HB248.650
The part number specifies the pad size... so it is the same number regardless of which Hawk you get ... you order by specifying pad type and size ... ie> HPS HB247.575 or Blue HB247.575 ....
For the track I switch to the Hawk Blue pads, though some folks run the Hawk HT-14 if they are actually racing the car.
I'd leave the stock rotors on for now, and see how you like the pads. The more aggressive the pads (Blue are more aggressive than the HPS) the more they will eat the rotors. I've tried slotted rotors, but I'm going back to the stock rotors as I really haven't seen much difference in brake performance (initial bite, fade, etc.) between the two rotor types. The new stock rotors are sitting in the garage and are going on this weekend. Replacing rotors gets expensive when you are using them at track events where they wear fairly quickly.
If you are looking at rotors as a "dress up" item, and don't mind the added expense, the Powerslot rotors IMHO are very good, and are well less than some "expensive" brake systems (Alcon, Brembo, etc.)
I think you'll find the Hawk HPS pads are an excellent choice for both street and some track use. ALWAYS check your pads before going to the track. Some tracks can really consume brake pads. If they are anywhere near 50 percent or less remaining on them, change them before you go to the track or you may well damage a rotor or two. Preferably, put fresh pads on for the track.
Hope this helps,
Steve
Old Feb 11, 2004 | 10:37 PM
Pumba's Avatar
Pumba
Bill,
When my Z06 comes out of winter hibernation in six weeks I will be installing the following brake components:
StopFORCE Porsche derived front rotors
EradiSpeed Plus 1 rear rotors
Goodridge braided stainless steel hoses and Speed Bleeders
ATF Super Blue DOT4 brake fluid
The StopFORCE rotors are far superior when compared to the OEM Corvette rotors.
I use Raybestos Quiet Stop pads, front and rear.
Good luck with your decision.
[Modified by Pumba, 3:58 PM 2/18/2004]
Old Feb 11, 2004 | 10:54 PM
Redshift's Avatar
Redshift
Platinum Supporting Vendor
Default Re: Looking for Brakes ! (Pumba)
For light track use, factory or Powerslot rotors would be a great idea. Get some decent pads - perhaps even a nice set for track only like Panther Plus or XP8 or XP9 if you are more advanced. Stainless lines are good, but not required (although I'm happy to sell you a set, :lol: ). Fluid like ATE Super Blue or Typ 200 or Motul 600 is a MUST for better performance.
If you want low dust, Raybestos Quiet Stop (same as GM pads) are incredible - I use them on the show car seen in my signature when the "bling bling" chrome 19" and 20" Imola wheels are on there and they never get dirty!
Let us know if we can help with any more braking advice. The factory brakes are excellent, but get very hot with heavy use.
Old Feb 17, 2004 | 09:02 PM
RyanC7's Avatar
RyanC7
Default Re: Looking for Brakes ! (Redshift)
I need those pads now... have to give you a yell.
Old Feb 18, 2004 | 12:15 AM
DocSandy's Avatar
DocSandy
From: When I say who is the mastah you gotsta say Shonuf
Default Re: Looking for Brakes ! (Gene@FredBeans)
:iagree:
Old Feb 18, 2004 | 09:27 AM
Gene@FredBeans
Default Re: Looking for Brakes ! (Ryan2002C5)
Please do... thank you for considering us..
Gene
Old Feb 18, 2004 | 10:10 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
call LGM and put some Wilwoods on the front
Old Feb 18, 2004 | 11:11 AM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
:lurk:
Old Feb 20, 2004 | 11:56 AM
EFI-1's Avatar
EFI-1
Default Re: Looking for Brakes ! (lager99)
Do the GM Ceramic pads dust less than the stock Z06 pads? Also, do they eliminate the brake squeal the stock pads have? :lurk:
Old Feb 20, 2004 | 12:05 PM
Redshift's Avatar
Redshift
Default Re: Looking for Brakes ! (EFI-1)
The Raybestos ceramics, which we have in stock at all times, dust WAY less (almost nothing) than the stock pads and are not squeaky at all. Just FYI :cheers:
Old Feb 20, 2004 | 07:23 PM
EFI-1's Avatar
EFI-1
:cool: I better order some stuff from you then....I got some miles to put onto my stock pads, but I'll hit you up when I decide to change. My transactions with PFYC have been flawless. :cheers: :thumbs:
To Looking for Brakes !
