[Z06] calipers
Old Feb 12, 2004 | 03:23 PM
joe03z06's Avatar
joe03z06
Default calipers
have the plus one rotors and the calipers hit only a portion of the rotors in the rear. What brand of calipers would you guys rec. for replacement?>
Old Feb 13, 2004 | 07:58 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Default Re: calipers (joe03z06)
no caliper that I have seen contacts the entire rotor
Old Feb 13, 2004 | 08:07 PM
joe03z06's Avatar
joe03z06
Default Re: calipers (John Shiels)
so when you upgrade your calipers they r not bigger?
Old Feb 14, 2004 | 10:20 AM
User 81424's Avatar
User 81424
You made a modification for looks only, and now it doesn't look that good, if you want to you can put a front caliper on the rear, with a front rotor too, but you will loose the parking brake.
Old Feb 14, 2004 | 10:48 AM
joe03z06's Avatar
joe03z06
Default Re: calipers (CPT Z06)
front calipers can go on the rear?
Old Feb 14, 2004 | 04:27 PM
User 81424's Avatar
User 81424
Yes, do a search in C5 Tech and General and you will find posts on how to do it, but you'll loose your parking bake. :yesnod:
To calipers
