[Z06] Z06 1/4 Times????
Old Feb 19, 2004 | 07:56 PM
CYA-Vett's Avatar
CYA-Vett
Default Z06 1/4 Times????
I have almost 1,000 miles on my Z and its getting warmer so I'm about ready to visit the track. What times should I expect, I have no mods....yet.
Also, how hard are they to launch, I used to run my GN but its a little easier to get off the line with turbo lag and an auto. I hope to eventually get the Z faster than the GN (mid 11's). Also with only a grand at my disposal any mod recommendations would be appreciated too....
Dave
Old Feb 19, 2004 | 09:28 PM
Z06gal's Avatar
Z06gal
Default Re: Z06 1/4 Times???? (CYA-Vett)
I only try drag racing once a year at our corvette club sponsored event in Sacramento, and my only previous experience racing was with our 72 Lt1. (so basically a beginner)
At the race in 02, my best time was 12.87. Last year did not fare so well- a 13 something :( (but everyone else was slow too due to the track condition so i guess i dont feel too bad)
Old Feb 19, 2004 | 09:38 PM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Depends a lot on altitude too. I went last fall in Calgary, about 3500' with just heades on my car. Track was greasy so 60' times were about 2.5 seconds...way off what they should be. Anyways I was 12.998-13.1. :cheers:
Old Feb 19, 2004 | 09:54 PM
pk2401's Avatar
pk2401
St. Jude Contributor
My best was a 13.001 @ 111.124 mph
But that was with a DA of about 6000'.
Old Feb 20, 2004 | 08:34 AM
CYA-Vett's Avatar
CYA-Vett
Default Re: Z06 1/4 Times???? (pk2401)
Wow, I expected to see lower times, good to know, now I wont expect as much as I did.
Old Feb 20, 2004 | 09:19 AM
ScottZ's Avatar
ScottZ
With some practice, you should be able to get under 12.5 (I'm almost there :smash: ). As stated above, track prep and altitude make a big difference. Learn how to launch it (I'm still figuring that one out) and shift as close to redline as possible. Intake is probably the best performance mod for under a grand.
Old Feb 20, 2004 | 09:38 AM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
My only mods are an airbox change and some minor PCM tweaks.
Old Feb 20, 2004 | 10:24 AM
CYA-Vett's Avatar
CYA-Vett
Default Re: Z06 1/4 Times???? (rbartick)
If I can run mid to low 12's with an airbox, I'll order one today!
Was that on the stock tires?
Old Feb 20, 2004 | 10:29 AM
RussBt's Avatar
RussBt
Yes, stock tires. As I said above the only mods are an airbox and minor LS1Edit tweaks.
See here-> http://www.rbartick.com/race_z06.htm
Old Feb 20, 2004 | 11:07 AM
CYA-Vett's Avatar
CYA-Vett
Many people do not cinsider slicks mods....
Cool, you close to Englishtown? Race there alot?
Maybe you can help me hook up my car. I'm new to Vettes, may need some help.
Old Feb 20, 2004 | 11:31 AM
RussBt's Avatar
RussBt
Many people do not consider slicks mods....
In my book stock means the way the car rolls out of Bowling Green. I agree that others bend the rules a bit.
I am part of the -->East Coast Corvette Challenge<-- series so you can find me in car # 6291 at ETown during the events. Check the web page for the dates.
Old Feb 20, 2004 | 11:42 AM
lager99's Avatar
lager99
St. Jude Donor '06
Nice 60' with stock tires. :yesnod:
Old Feb 20, 2004 | 12:04 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi CYA-Vett -
My best is 12.92 with a 2.2 60' time.
It's not the car, but the driver.
Someone told me that for every tenth you pick up in 60' times, you get two or three tenths in ET - sounds good to me - I would love to get to 1.9 like rbartick.
best regards -
mqqn
Old Feb 20, 2004 | 12:21 PM
RussBt's Avatar
RussBt
Default Re: Z06 1/4 Times???? (mqqn)
That really depends on how you got that 2.2 60'. If your 2.2 60' is a result of massive wheelspin then hooking better and dropping a tenth in the 60' will probably drop your ET by 1.5 to maybe 2 tenths.
On the other hand, if your 2.2 60' is a result of a hook and bog situation then dropping a tenth in the 60' is probably not going to give back 2 tenths at the big end.
There really is no set rule that relates the 60' to the 1/4 mile ET. Your 1st to 2nd shift is also a critical part of a good ET.
[Modified by rbartick, 3:07 PM 2/20/2004]
Old Feb 20, 2004 | 01:39 PM
niphilli2's Avatar
niphilli2
The rule of thumb is 1.5 tenths at the end of the quarter for 1 tenth on the 60', but like rbartick said there are may variables.
You will see times vary from 11.9@118 to 13.1@112 depending on driver altitude and weather. :cheers:
Old Feb 20, 2004 | 01:44 PM
mqqn's Avatar
mqqn
Cruise-In V Veteran
Thanks guys-
My problem is wheel spin - I am looking forward to BG this May to see if I can better my performance.
Best regards -
mqqn
Old Feb 20, 2004 | 02:40 PM
robz's Avatar
robz
The key for you is seat time. Also when your at the track go and chat with people to pick up tips. Ill be around etown and atco this year and would be glad to help you in any way.
To Z06 1/4 Times????
Old Feb 20, 2004 | 02:50 PM
CYA-Vett's Avatar
CYA-Vett
Default Re: Z06 1/4 Times???? (robz)
Thanks, I don't live to far from either track so I'm hoping to get there fairly often, we'll have to keep in touch so I know how to find you...
Dave
Old Feb 20, 2004 | 04:08 PM
pk2401's Avatar
pk2401
Damn good ET rbartick. Another mod and you'll need a roll bar.
[Modified by pk2401, 1:09 PM 2/20/2004]
Old Feb 20, 2004 | 04:33 PM
RussBt's Avatar
RussBt
Thanks. My current setup will run 11s this season as is. It just depends on the weather and how hard I want to push it. If CYA-Vett lets me make a pass in his stock car I should be able to get at least a 12.4 (probably better) out of it on a cool day as long as he does not mind me abusing it a bit ;)
