[Z06] Door rattle from bass
Old Mar 9, 2004 | 02:41 AM
bryce0011's Avatar
bryce0011
Default Door rattle from bass
how to fix this and what is rattling? thanks
Old Mar 9, 2004 | 05:05 AM
EFI-1's Avatar
EFI-1
Default Re: Door rattle from bass (bryce0011)
:lurk:
Old Mar 9, 2004 | 11:42 AM
Paul_Z06's Avatar
Paul_Z06
I had the same problem. Took it to the dealer and they were aware of the problem. Fixed under warranty. Haven't had the problem since.
Old Mar 10, 2004 | 10:48 AM
leaftye's Avatar
leaftye
Default Re: Door rattle from bass (Paul_Z06)
I'm sure it's the Bose emblem. Put a finger on the emblem when you hear it rattling. I squirted a shot of superglue behind my emblems, and it's been rattle free for over a year.
Old Mar 10, 2004 | 12:27 PM
zo6fun's Avatar
zo6fun
Default Re: Door rattle from bass (leaftye)
You sure that's all you squirted back there? haha, kidding
I had the same problem, also had some rattling from the plastic cover right below the rear window. I glued the emblems and it took care of the problem and then put some foam squares on the backside of the plastic crossmember and that fixed the rattling from it too. Of course, I have two 10" subs back there, so that was part of the problem too.
:D
Old Mar 10, 2004 | 01:12 PM
dubya's Avatar
dubya
St. Jude Contributor
Default Re: Door rattle from bass (zo6fun)
There is a fix for that. I think it can be found in here.
http://corvetteactioncenter.com/kb/category.php?catId=8
Old Mar 11, 2004 | 01:10 AM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
The stereo should have a treble & a rattle control. :smash:
Old Mar 11, 2004 | 01:46 AM
SQEZN BI's Avatar
SQEZN BI
How did you get a fish in your door? Maybe its the hook.
Old Mar 11, 2004 | 08:28 AM
theblackvette's Avatar
theblackvette
Default Re: Door rattle from bass (lager99)
:lurk:
Old Mar 11, 2004 | 07:00 PM
03-red-z06's Avatar
03-red-z06
I have the same frustrating problem!!!! The corvette action center does NOT have a fix. Anyone have any suggestions? Mine sounds like it is in the door panel...
Old Mar 11, 2004 | 09:02 PM
Kenny94945's Avatar
Kenny94945
I believe there is a TSB and saw it on this forum once.
Includes velcro-ing the door panel clips and wrapping the stryofoam in felt...plus 10 or so other items.
Old Mar 13, 2004 | 11:28 PM
Closer_2001's Avatar
Closer_2001
Default Re: Door rattle from bass (Kenny94945)
YES!!!
Old Mar 14, 2004 | 01:55 AM
Wadoka's Avatar
Wadoka
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
Default Re: Door rattle from bass (Closer_2001)
It's not the Bose emblem, any rate. My drivers' door buzzes like crazy at high volume, and I've got the non-Bose (no emblem on the grilles) system.
Old Mar 14, 2004 | 01:05 PM
DocSandy's Avatar
DocSandy
From: When I say who is the mastah you gotsta say Shonuf
Default Re: Door rattle from bass (Matt Black)
http://corvetteactioncenter.com/kb/q....php?qstId=276
Good Luck all.
[Modified by DocSandy, 12:07 PM 3/14/2004]
Old Mar 15, 2004 | 11:04 PM
SQEZN BI's Avatar
SQEZN BI
I took out the bose and put in diamond audio speakers 6 1/2'' 3'' 1'' with a 400x4 rockford fosgate amp and they get great bass and no rattles from door, or at least you cant hear them.
To Door rattle from bass
