[Z06] Adding HUD
Old Mar 20, 2004 | 01:27 AM
KLLRVET's Avatar
KLLRVET
Default Adding HUD
I am looking at a 2001 Z06, that does not have HUD. Can I add this to the car after I buy it? If so, what's involved?
Thanks,
Old Mar 20, 2004 | 10:26 AM
Z_OH_6's Avatar
Z_OH_6
Default Re: Adding HUD (KLLRVET)
The problem is that the Head Up Display unit works in concert with a special windshield so it isn't just a matter of adding the unit itself. The top of the dash and windshield will have to be replaced.
Old Mar 20, 2004 | 10:30 AM
theblackvette's Avatar
theblackvette
Default Re: Adding HUD (Z_OH_6)
You can have my HUD-
I hate it!
Old Mar 20, 2004 | 10:31 AM
brrymnvette's Avatar
brrymnvette
Incorrect, you can add HUD to any windshield. The difference is the reflection is not as clear, it is good just not as precise as a hud windshield. You might have wanted to post this in the tech or general discussion area. There are ALOT of guys who have done this.
Old Mar 20, 2004 | 10:35 AM
theblackvette
Default Re: Adding HUD (brrymnvette)
:iagree:
You'll have answers in seconds!
Old Mar 20, 2004 | 10:36 AM
fast4vette's Avatar
fast4vette
what he said.
the replacement cost of a HUD windshield is pretty high and many put in non-HUD replacement windshields and the HUD still works fine.
:cheers:
Old Mar 20, 2004 | 10:39 AM
theblackvette
Default Re: Adding HUD (fast4vette)
I say forget the 2001 and get a newer Z06!
I would love to :smash: my HUD!
Old Mar 20, 2004 | 11:16 AM
varkwso's Avatar
varkwso
Default Re: Adding HUD (theblackvette)
you can use the OFF switch.....
I really like my HUD... I wish it had more data options (flight vector diamond, bomb fall line, g meter, a DECENT shift light.....)
It is real handy for exit speed info for those of us with ham fists....
:steering:
Old Mar 20, 2004 | 11:35 AM
theblackvette
Default Re: Adding HUD (varkwso)
Yeah but you still see that box when the sun shines in a certain way!
Old Mar 20, 2004 | 11:36 AM
Z_OH_6's Avatar
Z_OH_6
I stand corrected. My impression was that the windshield is specific to the use of the HUD. While another will work, it will not fully duplicate the HUD-specific unit. I also agree that the question should be posed in the tech section. :cheers:
[Modified by Z_OH_6, 11:37 AM 3/20/2004]
Old Mar 20, 2004 | 12:29 PM
fast4vette's Avatar
fast4vette
the ONLY time i use HUD is on a road course. else, always off.
:cheers:
Old Mar 20, 2004 | 02:44 PM
Guest
Guest
Posts: n/a
Also, the top of the dash does not need to be replaced - there is a cut-out marked on the underside.
Old Mar 20, 2004 | 03:04 PM
CAPN17's Avatar
CAPN17
Default Re: Adding HUD (SamsBud)
You need the Hud projector and an gauge panel that has the connector pin on it, the cable that goes from the gauge pins to the Hud unit. There is a control unit and cable that mounts on the left side of th dash and then to the projector. You will also need the bezel that you use to trim the hole in the top of you dash. You can cut the hole yourself the location is pressed into the dash. As for the windshield there is a special unit, however there are chaps on the forum that have do it and not had a bit of problems with the stock windshield. If the search function is up try using that there have been several successful HUD additions done with no major heart attacks. Wish Icould help you more but I never did it, I got HUD stock and would not be without it.
Old Mar 20, 2004 | 03:06 PM
theblackvette
Default Re: Adding HUD (CAPN17)
I would like very much to pour cement in my HUD box and paint it black!
Old Mar 20, 2004 | 03:41 PM
Thud's Avatar
Thud
I wish my HUD had Tetris.
Old Mar 20, 2004 | 03:47 PM
theblackvette
Default Re: Adding HUD (Thud)
I wish my HUD would require a GM recall and have it taken out at their expense!
Old Mar 20, 2004 | 04:49 PM
Z_OH_6's Avatar
Z_OH_6
So BV are you saying you DON'T like your HUD?? :lol:
To Adding HUD
Old Mar 20, 2004 | 04:53 PM
theblackvette
I hate it!!!!
I have thought of filling up the HUD box with gasoline and lighting a match and throwing it in there!
But that would destroy the whole car. So I opted out!
[Modified by theblackvette, 9:53 PM 3/20/2004]
Old Mar 20, 2004 | 08:05 PM
blackz28turbo's Avatar
blackz28turbo
Hey BV. Why not have a poll on whether or not you like the HUD? :lol: :lol: :lol:
Old Mar 20, 2004 | 09:05 PM
theblackvette
Default Re: Adding HUD (blackz28turbo)
Blackz28turbo!
The poll would have two choices:
No and No!
:lol:
