[Z06] Light Feeling at Speed
Old Mar 28, 2004 | 08:07 PM
Closer_2001's Avatar
Closer_2001
Default Re: Light Feeling at Speed (ZO6Lee)
Check alignment
Old Mar 29, 2004 | 07:54 PM
NoWay's Avatar
NoWay
Having similar problem with my '01 vert since I have put headers on and reduced front weight by 30 lbs. I have driven up to 150 in desert roads of central Nevada and car stuck to road even better after I reached 120. However, now with headers and net loss of 30lbs when I reach 90 front end starts to lighten and starts to float about 100. Thinking about lowering front 3/4 inch and rear 1/4 inch. Any ideas? :confused:
Old Mar 29, 2004 | 11:25 PM
MikeNMaxZO6's Avatar
MikeNMaxZO6
Mine has the same feeling at full throttle launch, feeels like the car can fly!!!! Feels so good, although keeping up with a Turbo Porche up to 145mph, the butt end felt loose. Shut it down. :smiliedrool:
Old Mar 30, 2004 | 04:06 PM
Kenny94945's Avatar
Kenny94945
Good one about raising the rear...could help.
Of course I am assuming the shocks, alignment and tires are all correct.
Your front spoliers are still on?
Personally, I have not noticed this problem. I would guess shocks are bad or base suspension limitation. Look for an shcok oil leak.
Lastly, and I am only commenting here, at high speeds perhaps the C5 is trapping air under the hood ala the C2. A vented hood may be an option.
