[Z06] Trunk lid does not fully pop
Old Mar 22, 2004 | 06:12 PM
jerome's Avatar
jerome
Default Trunk lid does not fully pop
Does anyone else have the problem of the trunk lid not fully popping ?
In the beginning it would fully pop, and be easy to grab and lift, now it only partially raises and I need to stick my finger in a rear corner to grab it, or wait another 10-15 seconds, then it finally raises like in the beginning.
Maybe there is a drug for that ? :rolleyes:
[Modified by jerome, 3:14 PM 3/22/2004]
Old Mar 22, 2004 | 09:00 PM
JoeyNigs's Avatar
JoeyNigs
Default Re: Trunk lid does not fully pop (jerome)
Mine acts up once in awhile. Glad i have small fingers ! :steering:
Old Mar 22, 2004 | 09:13 PM
MadMaxZ06's Avatar
MadMaxZ06
Mine does the same thing, but only in the cold weather. I think the cold weather makes the rebound more sluggish.
Old Mar 22, 2004 | 09:16 PM
ModRed405's Avatar
ModRed405
Default Re: Trunk lid does not fully pop (MadMaxZ06)
Happens to me, too. No biggie, though. We'll see if warm weather fixes it.
Old Mar 22, 2004 | 09:26 PM
smook's Avatar
smook
Default Re: Trunk lid does not fully pop (Christian)
Everyone has this!
WD-40. spray on cloth only, then apply cloth.
Worked for me.
Bill.
Good luck.
Old Mar 22, 2004 | 10:35 PM
jerome's Avatar
jerome
Default Re: Trunk lid does not fully pop (smook)
Apply a lubricant to the rubber seal, right (not on hinges) ?
I would think of using a silicone lubricant instead of WD40.
Old Mar 22, 2004 | 10:43 PM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Here ya go:
http://forums.corvetteforum.com/zerothread?id=728281
http://forums.corvetteforum.com/zerothread?id=727439
http://forums.corvetteforum.com/zerothread?id=676743 :seeya
Old Mar 22, 2004 | 11:00 PM
jerome's Avatar
jerome
Default Re: Trunk lid does not fully pop (lager99)
Thanks guys.
Old Mar 23, 2004 | 12:49 AM
Tonys torch's Avatar
Tonys torch
Someone else posted on this not long ago.
My 2002 Z always did what your saying bearly enough room to get a finger tip in. I use to pop the hatch and then get out and shut the drivers door and this made the hatch open further. I really think its an adjustment
because my 2004 Z hatch pops open really nice.. about 2 inches everytime, it was the first thing i noticed transfering my stuff from the 02 to the new 04.
I thought WOW thats how its supose to work.. very nice with the two inch gap when poped.
Bet you can adjust it somehow.
good luck on the car. Tony
Old Mar 23, 2004 | 01:28 PM
jerome's Avatar
jerome
Default Now fine again
I used silicone spray into the mechanism and wiped some on the rubber seal, and now it pops up nicely. Thanks !
Old Mar 23, 2004 | 03:05 PM
washguy's Avatar
washguy
Default Re: Now fine again (jerome)
Hi Guys....I was talking with Andy with z06 parts...and he has the fix for this very thing....get ahold of Andy!.... :cheers: Wash
Old Mar 23, 2004 | 05:51 PM
AFVETTE's Avatar
AFVETTE
My buddy with a vert solved the problem by installing some small (I'd guess about 1 1/2 long) springs at the base of the supports. They get compressed when you close the lid but hit the release and it POPS right up. I'll see if he can post some pictures for you guys.
It's a neat fix for very little $$$
Tom
Old Mar 23, 2004 | 06:30 PM
dubya's Avatar
dubya
St. Jude Contributor
Default Re: Trunk lid does not fully pop (AFVETTE)
Tom
Hmmmmm, not bad! :thumbs:
Old Mar 24, 2004 | 12:51 AM
Fastlane's Avatar
Fastlane
I just leave the driver door open, pop the trunk and then shut the door. The back pressure pops it right up.
:lol:
Old Mar 24, 2004 | 06:47 AM
AFVETTE's Avatar
AFVETTE
Here's a photo and description of the fix my friend came up with - it works great.
Text of repair
Got the springs at Home Depot. They've got about a 3/8 in inner diameter, a wire diameter of about 1/16 in, and are about 1 1/4 in long. They come two in a bag for a couple of bucks.
Installation is a matter of pressing the spring over the strut's shaft and then winding the spring around the shaft. It's not necessary to disassemble the strut or remove the end of the strut or even unfasten the strut from the trunk lid or body. Just work the spring around the shaft.
Also found that a liberal dose of WD-40 on all the hinge points makes a big difference, too.
Hope this helps
Tom
To Trunk lid does not fully pop
