[Z06] Optima Battery
Old Mar 31, 2004 | 08:05 AM
floydzepplin's Avatar
floydzepplin
7th Gear
Default Optima Battery
I had to replace my battery and went with the optima but I am having trouble mounting it. Before I modify the hold down I thouhgt I'd see if anyone else has a recommended solution.
BTW the battery hold down in my 2001 Z06 seems to be pretty simple. I'm surprised they will let you on the track with only that rubber thing to hold down the battery
Old Mar 31, 2004 | 08:20 AM
QS01Z06's Avatar
QS01Z06
Default Re: Optima Battery (floydzepplin)
try moving the battery around.. mine fit in perfectly at first i had the back of the battery(part near the cowl) not seated.. once i got it seated the hold down bolted right in...
Old Apr 3, 2004 | 12:07 AM
Fast Lane's Avatar
Fast Lane
CI 3-4-5-6-7-8-9-10 Veteran
Default Re: Optima Battery (QS01Z06)
I'm using this battery which fits perfectly.
Old Apr 3, 2004 | 12:39 AM
gasboy's Avatar
gasboy
Default Re: Optima Battery (Fast Lane)
my optima red top bolted right in.
Old Apr 3, 2004 | 01:25 AM
pwrshhftd's Avatar
pwrshhftd
Default Re: Optima Battery (gasboy)
them optimas sure is heavy
Old Apr 3, 2004 | 01:58 AM
jim482's Avatar
jim482
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '03 & '06
:thumbs:
mine did as well...
I also got the Optima hold down clamp just in case of a "fit" problem. The stock hold down worked just fine.
Old Apr 3, 2004 | 06:19 PM
WWK888's Avatar
WWK888
Default Re: Optima Battery (jim482)
Same here, my yellow top fit like the stock battery. Just play with it a little and make sure it seats in properly.
Old Apr 3, 2004 | 09:17 PM
slong's Avatar
slong
What is the weight of the Nascar Batt? :lurk:
Old Apr 3, 2004 | 09:24 PM
JimBacus's Avatar
JimBacus
Got LAPS?
St. Jude Donor '06
Default Re: Optima Battery (slong)
:lurk:
Old Apr 3, 2004 | 10:07 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
and what are the specs? CCA etc.
Old Apr 4, 2004 | 12:14 AM
C5Longhorn's Avatar
C5Longhorn
I didn't have any problems installing the Optima. Also, its a very heavy battery, which sucks for the weight added.
Old Apr 4, 2004 | 11:52 AM
Z.06's Avatar
Z.06
Default Re: Optima Battery (C5Longhorn)
There are two different models of Optima Red Tops that I see people putting into the C5. Remy Battery recommended I put in the 75/35-925, which fit perfectly after a little wiggling around. People are also putting in the 34/78-1050, which has more cranking power, but weighs 6 - 8 lbs more. I decided I didn't need more cranking power and wanted to respect the original goal for lowering the car weight on my Z06. :D
Old Apr 7, 2004 | 12:33 PM
Gary@ronal's Avatar
0Gary@ronal
Former Vendor
Default Re: Optima Battery (Z.06)
I use the RED TOP, easy to install, works great.
http://www.ronalusa.com/cars/chevy_c5_z06_vette.html
:cheers:
To Optima Battery
