[Z06] Hurst Shifter Installation
Old Apr 2, 2004 | 03:30 PM
flibyu's Avatar
flibyu
Navigator
Default Hurst Shifter Installation
I'm going to add the Hurst as my next mod. I haven't bought it yet so I don't have their installation instructions and I'm wondering if I can do the job myself or not. How much work is involved to drop in the new shifter? Thanks in advance!
Old Apr 2, 2004 | 03:33 PM
1%r's Avatar
1%r
St. Jude 15 Year Donor
St. Jude Donor '03 through '17
Default Re: Hurst Shifter Installation (flibyu)
If you do a search there are some really good simple install instructions on this forum.
:cheers:
Old Apr 2, 2004 | 03:39 PM
CAPN17's Avatar
CAPN17
It is as easy as falling off a log if the download the how to from the forum and follow it and the included Hurst instructions.
Old Apr 2, 2004 | 03:54 PM
flibyu's Avatar
flibyu
Navigator
Thank You. I found the installation instructions.
Old Apr 2, 2004 | 04:39 PM
AFVETTE's Avatar
AFVETTE
You'll want the instructions CF member Patches authored. Its one of the best I've seen. Yes you can do it. Its actually very easy. Your biggest challenge will be removing what is commonly called the "demon key" its a small wedge shaped pin that tightens the OEM shifter ****. Some times it can be a real bear to get out.
If you re-use the OEM **** be prepared for rattles and buzzes. Seems the super stiff Hurst transmits harmonics back up to the tip of the **** which can cause some noise. I finally found a line of ***** that don't make any noise with the Hurst. Consider MGW if your out looking for *****.
Here's mine mounted on my Hurst
Good luck and the Hurst actually gets better with use.
Tom
Old Apr 2, 2004 | 05:52 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Default Re: Hurst Shifter Installation (AFVETTE)
Like said there's some good detailed instructions w/ pics floating around. Basically you....
1. Remove demon key and shift **** (do it by using two small screw driver on each side, not vice grips. You'll see what I mean when you get to it)
2. Remove center console and radio trim
3. Remove "gasket"
4. Remove stock shifter (four bolts)
5. Install hurst
6. Put it all back together.
Tooke me 2 hours even droping a shift stop that I was removing into the tranny tunnel.. that was a PITA!
Old Apr 2, 2004 | 08:30 PM
Fast Lane's Avatar
Fast Lane
CI 3-4-5-6-7-8-9-10 Veteran
Hardest part for me was removing the demon pin :mad which I got out by rocking it back and forth with vice grips. Also don't drop a bolt in the tunnel like me. :crazy:
Old Apr 2, 2004 | 08:44 PM
Piranha's Avatar
Piranha
Also, deffinitely do the PVC rubber cap mod. It muffles at least 75% of the rattle. I don't know the link but you can do a search for it.
Old Apr 2, 2004 | 09:00 PM
skip89's Avatar
skip89
Default Re: Hurst Shifter Installation (Piranha)
Would someone be able to post a link to the installation instructions ? Thanks if you can.. :)
Old Apr 2, 2004 | 09:16 PM
miami993c297's Avatar
miami993c297
Default Re: Hurst Shifter Installation (skip89)
A very very good mod to have the Hurst smooth and quiet, I did it, go & check this link:
http://www.z06vette.com/forums/showthread.php?t=47409
Christian
[Modified by miami993c297, 8:17 PM 4/2/2004]
Old Apr 2, 2004 | 09:25 PM
Piranha's Avatar
Piranha
Default Re: Hurst Shifter Installation (miami993c297)
That seems like a lot more work than buying a $2 PVC rubber cap and drilling a hole and sliding down the stick into the gasket opening. But this does look nice and may sound even better.
Here is the link for the PVC cap mod. Scroll down to KCvetteowner's comments...
http://forums.corvetteforum.com/zerothread?id=657449
[Modified by Piranha, 9:28 PM 4/2/2004]
Old Apr 2, 2004 | 09:30 PM
thx2.net's Avatar
thx2.net
In case you want another DIY document with photo's I did this when they first came about about 2 years ago..
http://www.thx2.net/hurst.htm
Old Apr 2, 2004 | 09:32 PM
miami993c297
Yes may be longer work than PVC Rubber Cap mod but since the HURST Shifter Boot is on my Z06, no way to unmount anything about the Hurst Shifter, the job seems to be done for ever !!
Christian
Old Apr 2, 2004 | 09:36 PM
Piranha's Avatar
Piranha
Here is the link to Patches install...
http://temp.corvetteforum.net/c5/pat...rInstall.shtml
Enjoy!!!
Old Apr 3, 2004 | 01:40 AM
4N EATER's Avatar
4N EATER
get a buddy to hold the towel on the shift ***, while u take 2 screwdrivers to get the "demon key" out. That was actually one of the easier steps on my install :lol:
To Hurst Shifter Installation
