[Z06] Something weird happened today>>
Old Apr 5, 2004 | 02:45 PM
Dave C. '04 Z06's Avatar
Dave C. '04 Z06
Default Something weird happened today>>
I pulled over to make a cell phone call. I had to shut the engine off because my phone was in the glove compartment (locked). So I started the car again and sat there with the engine idleing while I talked. After I was done, I started to drive and suddenly the engine just quit and there was a message in the Info Center that said "Remove key for 10 seconds".
What the heck was that?
After I did this, I put the key back in and the car started and ran fine.
Is this like a Microsoft Windows Cntl-Alt-Delete thing here?
-Dave C. '04 Z06
[Modified by Dave C. '04 Z06, 7:46 PM 4/5/2004]
Old Apr 5, 2004 | 03:13 PM
HummelS's Avatar
HummelS
Default Re: Something weird happened today>> (Dave C. '04 Z06)
If you turn the key twice before the column lock has had time to cycle, that will happen - it wants a "reboot" so it can figure out what position the lock is in.
Old Apr 5, 2004 | 03:25 PM
WisconsinVETTE's Avatar
WisconsinVETTE
Senior Member
Cruise-In V Veteran
Default Re: Something weird happened today>> (thevettenet CA)
Never had that happen to me
Old Apr 5, 2004 | 05:13 PM
Dave C. '04 Z06
TheVetteNet: Thanks for the info.
So from your response I assume nothing abnormal happened, I just must have switched the key on twice or too fast or something.
-Dave C. '04 Z06
[Modified by Dave C. '04 Z06, 10:13 PM 4/5/2004]
Old Apr 5, 2004 | 05:57 PM
HummelS's Avatar
HummelS
That's my guess - it's documented in the manual. If the computer can't figure out what position the lock is in, it will cut the fuel, the same as it's supposed to do if you try to drive with the column locked.
Old Apr 6, 2004 | 09:14 AM
Swimmer's Avatar
Swimmer
That same thing has happened to me a few times. No big deal. :cheers:
To Something weird happened today>>
